Last Update: 5-27-09
1972 & 1973 Honda's
Models made: ATC70, ATC90
ATC 70 (1973 start)
1973 Frame numberATC70-1000001~ on up
1973 Engine numberATC70E-1000001~ on up
Engine type4 stroke, Air cooled
Displacement72cc
Bore x Stroke47.0 x 41.4 mm
Compression ratio7.5 to 1
Compression142 - 170 psi
Transmission speeds3 speed
Clutch Type Automatic
Oil Capacity1 Qt ?
Carburetion?? mm Keihin
Starting systemRecoil Starter
Fuel capacity0.55 Gal , 0.11 Gal res.
Wheelbase 36.2 in.
Overall Length51.1 in.
Overall Width31.5 in.
Ground Clearance?? in.
Seat height22.4 in.
Front tire16 x 8 x 7
Rear tires16 x 8 x 7
Front suspensionnone
Rear suspensionnone
Front brakenone
Rear brakeDrum
Final driveChain
Dry weight163.1 lbs
Approx. retail new???.??
US90 ( ATC90K1)
Frame numberUS90-200001~ on up
Engine numberUS90E-200001~ on up
Displacement89.5cc
Bore x Stroke50.0 x 45.6mm
Transmission speeds4 speed with Dual range
Oil Capacity1 Qt
Carburetion16mm Keihin
Fuel capacity1.6 Gal , 0.3 Gal res.
Wheelbase 40.0 in. ?
Overall Length63.0 in. ?
Overall Width38.2 in. ?
Ground Clearance4.3 in. ?
Seat height25.0 in. ?
Front tire1pc tire & rim 22 x 11 x 3.5
Rear tires1pc tire & rim 22 x 11 x 3.5
Rear suspensionnone
Front brakenone
Rear brakeDrum
Final drivechain
Dry weight???? lbs
Click here for the Spec's Main Page
Here is the Honda Specification Pages:
Honda 1970-1971 Spec's       Honda 1972-1973 Spec's       Honda 1974 Spec's
Honda 1975-1977 Spec's       Honda 1978 Spec's               Honda 1979 Spec's
Honda 1980 Spec's               Honda 1981 Spec's               Honda 1982 Spec's
Honda 1983 Spec's               Honda 1984 Spec's               Honda 1985 Spec's
Honda 1986 Spec's               Honda 1987 Spec's
Sections & Info
   Search this site or the web        powered by FreeFind
  Site search Web search
American Sand Association
Help keep the Dunes open, Visit the ASA's website and support them.
Want to:
Advertise here, Sponser us ( very cheap ), Add a Link, Add pictures, Ect. ?
The contact information is above.
Do you like this site? Can you donate a little money to help pay for the web hosting cost? If you can donate please email Billy ( HondaATC ) or Howdy and they will give you the info on how to donate. Thanks!!
Thanks For visiting
Over
Page Visit's
F.A.Q.      © Copyright 1999 - 2006 3WHeeLeR WoRLD. All rights reserved.       Legal
