Page 1 of 7 1 2 3 ... LastLast
Results 1 to 15 of 92
Thread: 250r build starting
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,244
    250r build starting
    well i have pushed a few 70's out of the way to build my girls a new 250r for dune season starting in october, its going to be hopefully a 230 pound fully wet 300cc drag bike wanna be!!! mostly for playing in the dunes and cruzzzing vendors row in the evenings,,, i have got almost all the goodies lined up ,,, so the build begins,, with chopping the rear off the frame,,,, i started with a 85 250r bare frame. 5565
    i added a couple of brackets to bolt a removable subframe on it,,, i wanted something lighter than the stock part,,, i built the subframe out of stainless steel,, without any brackets on it yet... the only things to be added will be a bracket for the aircleaner,, i will be using a +6 dura blue swingarm till i have time to build my own design,,, here is what the sub frame looks like so far,,, i am also not using the rear motormounts that are between the swinger,,, i am going to add a bracket off the frame like an 88 trx,,, so i also eliminated the stuff below the swingarm bolt,,, its just added weight!!! oh i punched a few holes in the brake pedal too!!!
    i raised the subframe height a little in the rear to sweep the seat to the front a little more than stock,,, should help to keep a little more weight foward too,,, i am going to use real short bend bars too,,, i like the look and it also keeps you foward a little ,,
    i found a very kool set of kx80 forks,,, they are inverted,, since i am not going to run front brakes these will work perfect,,, lighter than 250r forks and more travel,, best thing,,,,,,,,, they are only 42 mm on the top side , so i bored the stock clamps to 42 mm and slid them right in,,, perfect,,, trailing axle keeps the stock geometry too
    now for a few goodies,,, RPM aluminum adjustable to 6+ axle,, complete ready to play just 9LBS!!! LITTLE OUT OF FRAME DRAG PIPE,,, CHROME CLUTCH COVER TOO
    i also have a front hub coming from another member that was shaved to half of its original weight,,, should look pretty kool,,, i am going to use a marvim shaw rear shock in a no link configuration too,,, i'll post more pictures when i get it to a rolling chassis,,, i had to split 3 motors to get all the goodies i needed to build a good solid 300 cc motor,, i also sent the transmission in and had it cryrogeniticaly treated (FROZEN) SUPOSE TO MAKE IT LAST LONGER AND TOUGHER AND SMOOTHER,,, WE WILL SEE...
    OK
    5,450
    Awesome.. The parts alone amount to a mean 250R, can't wait to see this one in its next stage.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Masshole
    2,191
    When you bored your tripples, did you have to offset the holes towards the center to keep clearance for the pinch bolts?
    KASEY's Avatar
    4,244
    there is plenty of room to get the bolts in,, it was bored 3 mm total .. here is where i am now... got my rear shock and mounted the forks,,
    i scored a set of marvin shaw rear shocks on craigslist. so i am getting closer... i am shooting for a 1.5 to 1 shock ratio,, so i have to do a little work on the top mount... it will have 9" of smooth travel,, and 10 inches on the front,,, more than i wanted ,, but it will be chushy .
    Oct 2007
    Grosse Tete, LA
    3,440
    very nice Mr. Kasey...how heavy is that subframe compared to stock?
    KASEY's Avatar
    4,244
    its all thin wall stainless steel,, it weighs half of what i cut off,,, i incorperated the grabber into it to save weight too,,, no bolts,,
    boosted96cobra's Avatar
    boosted96cobra is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2007
    n utah
    279
    Amazing work man!
    http://i291.photobucket.com/albums/ll292/sagep11/IMAG0069-1.jpg
    84 tri-zinger
    85 ATC 250r
    86 TRX 250r
    85 ATC 350x
    86 ATC 200x
    KASEY's Avatar
    4,244
    off to the engine room,,, i installed new bearings in the good case half and started the tranny ,, i got a few new parts from bobs to insure a smooth trans operation,, shift drum like new and a shift fork was a little worn,,, i also put a better condition 2nd gear in ... as soon as i finish stripping the other side i can install new bearings and put it together,, i drilled and tapped a couple of holes in the bench to make a sterdy motor stand,,, that way when i beat the crap out of it putting it together it won't fall on the floor!!!:lmao: :lmao: :lmao:
    Columbia
    5,131
    Looks steeler Richard. Cant wait to see it in person this winter
    Aug 2005
    Lockport, NY
    2,395
    Made in indonesia you say? Nifty work. Fan of the allthread engine stand. Bravo.
    KASEY's Avatar
    4,244
    man i hope my whole family get a chance to come to the next version of "YOU WESTCOAST PEOPLE SUCK"
    KASEY's Avatar
    4,244
    MAN I GOT DEEP INTO THIS ONE , more than i thought to just freshen it up,,, but wow its ready to roll now,, the second motor i split was a cream puff!! i should have split it first i guess,,, but from looking at the busted case and the outside condition i figured the inside was as abused as the outside,,, WRONG .... so i get a perfect condition clutch new plates steel instead of aluminum plates... and a perfect kicker gear with very nice rachet gear,, so i should be ready for the rest tomorrow,,, working in the garage @ 113 really takes it out of you!!!
    Phoenix, AZ.
    6,719
    Get one of those Master Cool portable swamp coolers. I've been using one for the last three years or so. Works really well. Doesn't leak or anything. You just have to stay somewhat close to it and leave the garage door open.
    Jun 2009
    Tunkhannock,Pa
    904
    nice work man
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Mar 2009
    Utah
    203
    Gotta love the stainless
    3 wheelers:
    '85 ATC 110 (its my first restoration!!)
    Saving up for a 250r later this year!
