Thank you both....
Pics and manuals are always helpful!! Thanks for taking the time to help....
Jason, that part is not shown on the diagram, does this mean he has to buy a junk head to obtain one??
There is a large diameter bore about 10MM deep and then a small bore a bit deeper. The bike is not here anymore so I'm going off of memory, I should "see" this plug/cap in there I would think.....??
If it is in there, it's in deep and the oring must be bad.
I wonder why though, if there is NO PLUG, that oil doesn't pour out of there unless it is in a splash area and not a pressure area??
EDIT - If it's rubber than it must just be a splash area, thanks for the heads up!
I may just have to machine one up on the lathe. I gotta try and find a picture online so I know what I'm dealing with. Or just find a decomp shaft and cut off all the useless areas
