Thread: Using a 200s headlight on 125M?
    Nov 2009
    N Hollywood/ CA
    588
    My 125M is missing the front headlight, I happen to have a spare headlight from 85 200s. Is it interchangable? I know the the post set-up are slightly different on the headlight unit .
    Tionesta, PA
    5,747
    They should swap - what do you mean by post set-up? The mount points????
    Nov 2009
    N Hollywood/ CA
    588
    Correct, you know how the 110 there right behind the back so it sits flush with the forks, compared to the 200s where it has a bracket on the side.
    Tionesta, PA
    5,747
    I know they will swap because 100% sure. My brother has this aftermarket one on both his 110 and his 200s
    http://dratv.com/athekitinwo.html
