I have found an almost bolt on setup for the 250r,,,, 10.5 inches of travel. OEM triple clamps with zero degrees built in ,leading axle forks with caplier mount on the same side as a 250r. yep OEM from honda triple clamps. its going to take a little spacer work but no machine work... i am currently getting all the part numbers so i can see how expensive its going to be new .. but that means there are alot of used ones out there to find ,,, here is a pict of the setup with a front hub .. it will even use the stock 250r axle,,,
