Results 1 to 15 of 26
Thread: cold cutters
    Jun 2006
    holland, ohio
    1,587
    Question cold cutters
    Gonna get some screws soon, and I have no idea on what length screw works best and how many will I need to buy approx.
    Apr 2009
    alvordton oh
    70
    what tires do you have
    N.E. Ohio
    2,005
    20lbs worth
    Dec 2002
    Orange County, NY
    1,772
    We need A LOT more info to give you an accurate answer. What type tires? What size? What machine? What are you going to be using the machine for? Racing? Playing?
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    Yamatrike400's Avatar
    Yamatrike400 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    MINNESOTA
    393
    I am wondering the same thing ditch mud. I would like to get into ice racing. I have an 81' 300R and 20" cheng shins on alum. rims are going on it. Will probably be a combo of racing/playing. Any suggestions for me John?
    Three Air R's
    Dec 2002
    Orange County, NY
    1,772
    I would start with a box of 1000 1" screws.
    1986 Monstecate
    1984 ATC125M
    Jan 2008
    MINNESOTA
    393
    J/w but Would 3/8" rip out?
    Three Air R's
    Dec 2002
    Orange County, NY
    1,772
    Even 1" ones will rip out sometimes but 3/8" will definitely be spitting out regularly on something with some power that is getting slid around. If it were just to put some in something like a Big Red so that you can putter around on the ice then I'd say you'd probably be OK with the small ones. Also, pumping the tire pressure way up while you're studding them helps retain the screws (only the longer ones that penetrate the tire).
    1986 Monstecate
    1984 ATC125M
    Jan 2008
    MINNESOTA
    393
    Do you put slime or anything in the tires? Silicone on the screws?
    Three Air R's
    4cfed's Avatar
    4cfed is offline Just Too Addicted Arm chair racerJust too addicted
    Oct 2009
    wisconsin
    619
    shouldnt need 1000 of them, i ran 200 per tire on a quad and you could drop the clutch and damn near flip over backwards!!!
    i know here in wisconsin, the ice racers run one screw per lug on the chin shing tires, fronts dont nearly need as man as the rear, pretty much make apattern down the center 3 rows of lugs,
    the tires on the back of my 200x were on a piped raptor 660 and it had 1/2'' kold cutters and i think it only ripped out about 8 studs between the two tires,
    so il be running ether 1/2s or 3/4s in my 200x, and halfs in the cr125 ( i know they will rip out on the bike but i dont want to replace tubes come spring
    86 200x, 1st gen 200x axle,400ex hubs,fmf megamax2 muffler
    Three wheeler guys probably have the biggest balls out of all the ATV/Motorcycle riders. You just have to be a little twisted to ride them, and you have to be a great rider to do so.
    'let those who slide decide'
    CUYAHOGA FALLS, OHIO
    1,242
    Ditch. Get them hooked up. Im going to put together a ride down here at Portage Lakes. Its about 10 minutes from my house. Its a chain of lakes that are completely legal to ride on.......O and did I mention there are 7 bars right on the lakes to ride to and get some beverages.
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    Tionesta, PA
    5,747
    Max - let me know when you do this. I plan on stuffing some tires for raffas this year - and would love to come hang / ride with you and hit up those 7 establishments.
    Jun 2006
    holland, ohio
    1,587
    Ok I have some 18" turff tamers. But I'm thinking that they aren't going to work well because they seem to be of a softer compound. Let me look at what else I got.
    What length stud? And Sam what was that glue you used to help retain screws in your tires?
    Dec 2002
    Orange County, NY
    1,772
    If you get the right tires (Cheng Shin 826's) and 1" studs you don't have to worry about gluing the studs in or anything as long as you put them in the way I mentioned above. I stand by my suggestion to get the box of 1000. The rear tires take a lot of screws if you put one in each knob and you can always use them on your next set. Plus the box of 1000 comes in a nice plastic case that will keep them contained.
    1986 Monstecate
    1984 ATC125M
    4cfed's Avatar
    Oct 2009
    wisconsin
    619
    johnR or anyone else, ever studded fast trekkers??? im doing mine in a few weeks, and wondering if anyone found or knows a good way to stud them like.. heavyer on the studs in the muddle or on the outter lugs.. i know how to stud tires..
    i just want something thats gonna work for play riding, with the ocassional ice drag and of course ice oval!!! i plan on spending alot of time sideways this year!
