Results 1 to 12 of 12
Thread: Stripped drain plug...am I screwed?
    unclejemima is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2009
    Canada
    197
    I purchased a 86 atc125, and I changed the oil once since I got it. I always am cautious not to over tighten the oil drain plug. (it is on the bottom of the engine, not the side)
    Anyway, I went to drive it a few days ago and I noticed a little puddle of oil under the trike. I though, oh shat, where is that coming from? Put my hand underneath and it turned out just to be coming from the drain plug bolt. Ok, I figured I must not have tightened it enough, so I got my wrench out and gave it a few turns. Sure enough, it was loose, but it just kept spinning without snugging up. Damn, I thought.
    The bolt is still semi-tight (not finger tight, still need a wrench to loosen). Is there an easy way to fix this? Do I have to re-thread the hole or is that dangerous because of metal pieces?
    Any tips would be appreciated. This really sucks and has be bummed out. I hope it is fixable!
    Lancaster, PA
    1,738
    you can helicoil them, It does require drilling the hole a little larger, just drill slow and coat the drill bit with grease so some of the metal shavings stick to it.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Sep 2005
    Massachusetts
    1,272
    I heard my sv1000s has a problem with this. Many people have helicoiled them. It seems to work. I just dont know the process. Never had to do it!
    2000 Rm250
    1985 IT200
    2003 suzuki sv1000s
    2008 polaris outlaw 525s
    PA
    3,515
    I have used helicoils many times to fix drain bolts.
    I drain the oil and save it to flush out any metal that's in there. Use greese on the helicoil tap, that'll catch most of the chips.
    WWW.HREATV.COM
    Sep 2008
    Northwest Indiana
    550
    First thing, see if it can be re-tapped for a larger bolt. If so just re-tap the threads, you can use a vacuum cleaner to catch the shavings if needed. Before you finalize it, clean and flush the area for shavings. I had to do this to my kxt250......so if you go with a larger bolt, get a magnatized one if possible. This will catch all the junk at the bottom. Other wise drain the new oil and the stuff not caught will come out by way of gravity alone. Dont sweat it.......its been done before!
    1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
    Dec 2009
    Chicagoland
    318
    Temp fix: Teflon tape!
    Escanabajosh's Avatar
    Escanabajosh is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    U.P. (upper michigan)
    352
    the teflon tape will melt after a while, or so i was told cause i thought the same thing when i had this problom on my sx. i'd get the heli coil or a time sert kit. i still have to do this to my sx i just bought this thing at carquest that has a drain bolt within a bolt )hard to explain) but i put that and some thread sealer on it and havent had a problom. it was a temp fix i never got around to permenant fix yet.
    Dec 2002
    Orange County, NY
    1,772
    The one in my R was stripped when I brought it home many years ago. I brought the old one to the auto parts store and figured out what size it was, then I found what car/truck took the same size drain plug and grabbed one of the "one oversize" ones from the HELP section. They have a tip that will cut new threads just a little bigger than the original but the problem was that it was too long and wouldn't screw all the way in so I ran it in until it bottomed out (I guess on the gears) and took it back out. At this point it had cut the threads needed for the oversize plug to fit in so I just carefully hacksawed off the part of the plug that was tapered to cut the threads and put it all back together. That was about 15 years ago and just this season the plug stripped again. Not too bad for an easy, cheap, fix that didn't require any special tools or anything. IIRC this time the hole was just big enough for a 1/4" NPT brass pipe plug so that's what I went too.
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    Especially with aluminum, the hole is already just a bout sized.
    You won't need to drill it out, just use a helicoil tap (about 20$) and a coil (about 1$)
    I do like the threaded inserts better for this application because it will be loosened a couple/few times a year.
    A grab bar and other items I love using helicoils on...............
    Oct 2009
    Canada
    197
    Thanks guys! I was worried that this would be a big deal. I really appreciate all the advice!
    I'll get on it this weekend.
    Take care,
    SW Michigan
    73
    Lots of good advice here already. I'd go the helicoil route first, usually the strongest fix and will last. Be sure to coat the treads (tap) with grease to catch chips like was said above. If the helicoil fails sometime down the road you can then drill/tap to next oversize. I usually flush any extra debris out with kerosene, let it drain out. Fill with oil, run up to temp, then drain the oil again to be sure you got any other chips out. Refill and your off riding. If none of those work for you I've got extra 125 cases I could put on ebay. Good luck!
    '74 ATC70 (stock for my nieces)
    '84 ATC70 big carb, race cam, and piped (big boys little toy)
    '84 ATC125M
    '85 ATC125M
    '85 ATC185S (200X carb and pipe)
    '83 ATC200X (my first trike ever, avatar pic)
    '85 ATC200x
    '85.5 Tri-Z 250
    '85 ATC250R
    '79 CJ7 w/351 Cleveland
    '77 XL75, '78 XL125
    '88 Katana 1100
    '00 King quad
    '05 LTZ400
    Phoenix, Arizona, United States
    24
    Someone said this earlier I think, but my friend bought an oil drain plug at the auto store that is meant for this exact situation. It's bigger and as you tighten it in, it makes its own threads. Its supposed to be for cars but it seems to have worked for his 250r
    ... Go to my Youtube Channel ...
    -2003 Stroked KX125
    -2007 Yz450F " Fo Fiddy! "
