Results 1 to 15 of 20
Thread: DO NOT USE ON A HONDA TWO PIECE RIM! (why not?)
    tundrawolf is offline At The Back Of The Pack Arm chair racerFirst time rider
    High desert, CA
    176
    All 3 of my tires on my ATC say "DO NOT USE ON A HONDA TWO PIECE RIM". Well, the tire on the front, which is a Honda two piece rim, says that. Why not? I am getting a good used tire, which will go on the front, and I will put the front on the rear along with the other old one. Apparently, even the front tire said not to, but the previous owner had it on there anyway. Can someone tell me why?
    leroy, new york
    1,025
    I have always had problems with the two piece rims, they would never reseal and always off balace. i tossed them all out and got one piece, one peice rims are a dime a doze around 5 to 15 bucks each.n
    Michigan
    1,144
    When I redid my 73 atc 70 I had the wheels apart, blasted them, painted them and got new O rings from my Honda dealer and put them back together and never had a problem.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Springfield Mo
    3,309
    Put a tube in the split rims. I have never had a problem doing that.
    Tionesta, PA
    5,747
    I have many split rim wheels on multiple trikes I own - never ever had a problem. You have to use new rings when you split them though! real cheap through dratv.com.
    Oct 2009
    brazil indiana
    839
    tires for 2 piece rims have a wide sealing surface. a tire for a one piece rim has much less and require a lip made into the rim that it has to pop over the top of. this lip helps keep the tire on the rim. i have seen many one piece rim tires on two piece rims and not have a problem but if you were to do real hard turning with good traction it may want to pull off the rim.
    1,736
    i run a one piece tire and all 3 of my 2 piece rims, no problems at all.
    Someone was using the roofing rubber (commercial type) for a gasket between them and loved the stuff..............
    Sounds like if you do it properly, your AOK; Or just get a welded rim and be done with your issues.
    Oct 2007
    Anna, Tx
    165
    For a seal between the the 2 piece rims, I have always used a piece of old inner tube with a little silicone smeared on it. Always works good.
    85 200x
    84 200x-autox
    84 200s--parted out
    85 70
    85 70
    84 70
    69 QA50
    70 trail70
    81 yz250
    82 yz80
    High desert, CA
    176
    Quote Originally Posted by jensenracing77 View Post
    I believe you are correct.
    COLORADO
    685
    I run black RTV on them and they hold up great. I did that on all my split rim vehicles, and never had a flat or a bead pop.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    High desert, CA
    176
    Quote Originally Posted by 3wheelmecca View Post
    Now, are you talking about putting RTV between the rims, or putting RTV where the bead goes?
    Sep 2007
    100mi west of Chicago
    3,582
    Quote Originally Posted by night4creeper View Post
    I finally had a chance to try this recently. Seems to be working pretty good on my old 110. Before this I had just tried to silicone the 2 halves together and that worked ok for a while but they started leaking again.
    Rob
    May 2007
    Orange County, NY !
    1,673
    ^^^^^^^^^^^^^^^^^^^^^^^^^What he said^^^^^^^^^^^^^^^^^^^^^^^^
    The tires that came on two piece rims had a wide "bead"(more of a flat rubber surface). The rims I think don't even have a lip for the bead. That was the whole point of the two piece rim, you didn't have to fuss with trying to get the tire over the lip, or the bead in the grove..
    Having said that, I think I have regular tires on my two piece rims, and they work just fine. Cleaned them up and sealed them and they have been holding air for years.
    Apr 2006
    SE CA Dez in the sandbox
    900
    Quote Originally Posted by trikes4life View Post
    .... they would never reseal and always off balace.
    Now that's curious...how did you determine it was the rims which were off balance and not the tire?
