Page 1 of 6 1 2 3 ... LastLast
Results 1 to 15 of 86
Thread: New suspension 70 build
    Sep 2009
    Ireland
    89
    Cool New suspension 70 build
    My 70 frame snapped in half a while back so I've now rounded up most of the parts to build my suspension frame. I'll post more pictures here as the build progresses.
    I'm using a pit bike frame, making my own swingarm and triples.
    Today I've been sizing everything up on the bench, trying to work out what wheelbase length I want to go for. I don't know how the extra length, width and rake affects the ride so it's really hard to decide. Maybe some of you guys can help me out here; The A+ frame looks about right to me - it obviously has a longer wheelbase than stock, can anyone tell me exactly what it is (or the length of the A+ swinger) and did the A+ use wheel spacers to increase the width to keep the overall geometry the same?
    Winnipeg Mb
    113
    This will be a sick build!
    1988 Honda TRX250R
    fmf pipe, ct national port airbox lid removed worcs front shocks renthal bars maxxis razr's
    1985 Honda Big Red 250ES
    1984 Honda Big Red 200ES
    1982 Yamaha Tri Moto 175
    Please Check Out My Youtube Channel
    http://www.youtube.com/watch?v=Mbwd1...feature=relmfu
    Southern MN
    1,875
    Nice start to a good build! Keep up the good work, and keep the pictures coming! I really like seeing the 70's with suspension, and even more of them being jumped! It must be a riot.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    May 2009
    Minnesota
    457
    Looks like a pretty solid project.
    1982 Honda Big Red 200e
    1985 Honda 200x- sold
    1986 Honda 125m- sold
    1986 Honda Big Red 250es
    1986 Honda 250sx
    cox's Avatar
    cox is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    Edmonton alberta canada
    552
    thats pretty sweet. me likey
    R.I.P. Yamahondaman
    Still practicing my NoobiX cube, take it easy on me...
    1982 Yamaha YT175J ( Not much left but the 's)
    1982 Yamaha YT175J
    1983 Yamaha YT125K + 175J =
    1984 ATC 200ES BR - running again - Camchain noise holding me back....
    1984 ATC70 -SOLD-
    Sep 2009
    Ireland
    89
    Thanks for all your help...
    Made a bit of progress on the swing arm today:
    All I need to know now is the what length it needs to be - anyone???
    krazykane is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2009
    morrisville pa
    229
    well iam just thinking outside the box but a little longer is prob better just like a extended swingarm.i dont have one but iam diff going to watch this build cause i have everything in the making to do this so .in due time i will be doing this .and i mean longer then the stock length on the stock 70 .
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    ONE THING TO LOOK AT, the neck is alot shorter and the top clamp will hit the tank right in the middle.. so adjustsments will have to be made there,,,
    Sep 2009
    Ireland
    89
    Thanks Kasey, I hadn't thought of that. Just looked at a few pictures of 70's on pit bike frames, they seem to have moved the tank back far enough to avoid them hitting, without it looking odd. I'll watch out for it.
    Sep 2009
    Ireland
    89
    Got a bit more work done on the swingarm and frame this afternoon - swingarm is 13 inch / 330mm
    I'll be making the yokes this weekend from these slabs of billet ali:
    Front forks and rear mono shock are new pit bike parts:
    Should hopefully be a roller by the end of the weekend.
    Springfield Mo
    3,309
    Keep us in the loop!
    Sep 2009
    Ireland
    89
    I got the swingarm spot welded together, didn't want to weld it all in case I need to make changes. Also lowered the rear shock mount on the frame because it was in the way of the seat.
    Marked out the bottom clamp ready for drilling and cutting.
    I like it :
    There are 1000 ways of building a suspended 70..........
    What do those forks cost? and where can I grab a set, I was gonna chop down some 200X forks but those look pretty trick!
    I think you may be angling that shock back a hair. Like you said, thats why it's just tack welded. The same reason I do it that way too.............
    Nice work so far!!
    Sep 2009
    Ireland
    89
    Thanks Dirtcrasher, it's nice to get some feedback......
    The forks are Marzocchi non-adjustables - Goggle it. They're Italian high quality forks, a proper adjustable set costs about $700!!!!!!!
    These are only sold as part of of pit bike but occasionally they turn up on ebay form new bikes that have been dismantled for about a $100.
    The rear shock is only 11 inches long, and the seat height as it is now, is 26 inches. I'll see how it rides, but you may be right.
    Sep 2009
    Ireland
    89
    In my haste to get the triples done I made a stupid mistake on the setting out, luckily I spotted it before I messed up the 2nd one. Managed to make a couple of 1 inch wheel spacers out of the centre part of the 1st but it meant I had to drive all the way out to the metal supplier today to get a replacement. Hopefully I'll get her rolling later this week.
