Nice build!! You need to update your signature to read: Bad Azz 500X!
RIP Ninja!
Trike Fest 2011, 2012 Vet!
Trikes Currently Owned:
87 Big Red 250es
83 Honda 200s
81 Honda Atc 70
(4) Suzuki ALT 50's
Yamaha YT 60
Don't rub it in, . atc400x is keeps on dropping the hints as well, . I have already made plans with my wife to go to Panama . But I do have the ok to go the following year if they still have it . This way I can play at Silverlake to work out the bugs before I travel across the U.S.
R.I.P. Sandpuppie, you are greatly missed!
May you rest in peace Jeswinehart, deeply missed, never forgotten....
Feedback thread http://www.3wheelerworld.com/showthr...ight=tapper190
this build looks great!!
I was out in the garage this afternoon and managed to get the 500 almost complete. I like this kick starter a lot better than the last one. It just clears the fenders, but you can't really get a good strong kick. Hopefully it will be a one kick bike once it gets warm and I won't have to remove the back fenders.
The only thing I have left to do is put new brake pads front and back, put the chain on (which is coming from my good friends at Full Bore Power Sports in Missouri) and mount up the engine skid plate. I also want to make a case saver and cover for the engine sprocket. If anyone has one please let me know or I'll be trying my hand at fabing one.
It feels almost perfect when you are sitting on it. I'm 1" lower to the ground than the 350x, but my seat height is about 2.5" higher. The rear suspension feels sweet as well. I think I'm going to add some spacers inside the front forks to stiffen them up. Other than that I can't wait to get it out for a test run!
Again, sorry for the poor quality of pictures, I'm not to good with a camera,
Tapper
This was a great build, tapper
post o vid of it running/riding when your done, please
and let some air out of those tires
normally the rake on a bike conversion looks really out there. how did you get the rake pulled in so tight?
tapper do you have macro on your camera ? I cant wait to see your machine in person !!
1985 250sx (Lemon)
1985 250sx (Ruby)
1985 250sx (Garnet)
1985 200m (Hunter)
Man Dave that thing looks Right! You did a Awesome job building that thing, looks like It rolled off the show room floor from Honda!!!
83 ATC 70.
83 Tri zinger
ATC450AF
86 310-R Drag racer
If that dont SCREAM SLEEPER .. I dont know what does.... to the un trained eye that motor is hard to spot in there...LOL Nice build Tapper!!!
Nice job!! Very clean looking, can't wait to see it in person. Maybe you can test it out at the Trike Circus this year
My Youtube Channel:
http://www.youtube.com/profile?user=ditchmudrich#g/u
My Feedback:
http://www.3wheelerworld.com/showthr...k+for+ditchmud
Trike Circus is May 31,2014
I braved the cold temps. today to try out the 500. All I have to say is wow! That thing is wicked fast! I want to play with the gearing a bit. I think I will try it with 12/41 which is the same gearing ratio as the 500 (14/48) according to a web site that I found. I have a small oil leak which I think is from one of the valve adj. caps. The suspension work really great as well, It wasn't smooth but I was riding on a froozen plowed field with snow! No speed wables at all, didn't pull to one side at all on flat ground. I'm very happy with the first ride. I'm not to fussy with the twist throttle at all, I would rather have the thumb throttle, but like the idea of have the push/pull throttle so I know it won't stick open. I can't wait to get this machine in the sand!!!
Tapper
Isn't a +3 close enough? lol. I'm not really an aggressive rider, so I should be good to go. I'll probably be in shock with everything that I've heard about the place!
I'm having problems getting my paddles to seal right, they are GBC sand devils. I posted in the invasion thread,
thanks to everyones comments!
Tapper
