I would suggest not. There is an oil line leading to the main bearing on those. If you disable that, you will burn it up.
run a clear line from the injector from the pump to intake and start it up, that will show the oil physically pumping through it.
You will cry, you will scream if you've heard half the **** I've seen.
Are you gonna get up and burn an X in your head?
"Cut throught the bone and cut through the wire"
Trikes:
84&85 Tecates
85 R
85 X
Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
