It is kind of a PITA to do kicker gears, it is internal on those. I am building an 84 XR200R now, but as a flattracker. I had an 83 like that, but was lowered, bored, and had a cam. If you have any ?s on building it up PM me.
Also, I thought it had the integrated comp release on the kicker with a cable going to the head. My 83 had that.
I cant believe the gear stripped though, my TT500, that has to have the decomp, I kick without and end up breaking the kick return PLATE! Almost 220 lbs of comp on that.
You will cry, you will scream if you've heard half the **** I've seen.
Are you gonna get up and burn an X in your head?
"Cut throught the bone and cut through the wire"
Trikes:
84&85 Tecates
85 R
85 X
Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
