Results 1 to 8 of 8
Thread: 200x frame crack repair
    Manitoba
    536
    I have an 84 200x that had a frame crack repair done by a previous owner. The crack is on the front down tube right where the front motor mount plate bolt passes through. The previous owner welded an ugly, oversided gusset on the front of the tube. I'd like to remove the massive gusset, sleeve the tube with a split tube on the front and rear. The sleeve would cover the crack and be both above and below the bolt pass through. What do you think? Reasonable idea for making the repair cosmetically and sound?
    84 200x
    Manitoba
    536
    Here's a picture of the previous owner's repair that I want to re-do, more neatly.
    84 200x
    Apr 2006
    SE CA Dez in the sandbox
    897
    I've got two frames like that that were repaired by someone else. The best fix is to sleeve over the crack/break and mig/tig it in place.
    Looks like you've got some cutting and grinding to do
    Have '85 350X-XR500 Hybrid,
    Had Nicholson framed: 90/110, 185s, Gen I 500, Gen II 500
    Had Bandito Framed 90
    Have Vey's Framed 90
    Have too many parts
    Manitoba
    536
    Anyone know how the end of the sleeve should be to reduce it as a stress point. Do you taper it into a V at the ends, or fishmouth it to soften the transition and stress?
    84 200x
    Aug 2004
    Ab Canada
    4,368
    Is there a Hole in the bottom of that downtube Where it splits off for the engine cradle..? I haven't seen a 200x up close before...Might have an idea.
    1985 Tri-Z-
    Manitoba
    536
    Quote Originally Posted by MTS View Post
    Yes, the tube is open on the bottom. Very interesting possiblities. What are you thinking?
    84 200x
    Aug 2004
    Ab Canada
    4,368
    Just seen this again looking for another thread...Anyways...If its open on the bottom...Try Sleaving it from the inside with a Thick walled Pipe or solid slug...If its long enough all you would need is to drill a couple holes in the Frame Above and Below the crack to Plug weld it in...And drill the hole for the mount bolt...was what i was thinking...Little Better looking...and would spread the stress out over a larger area....I think.
    1985 Tri-Z-
    Manitoba
    536
    Yeah, good idea. I like it a lot. I just have to get it past the bolt holes, then redrill it for the motor mount bolts. Hopefully there is no snag at that point. It cracked right at the motor mount bolt boss, so that rigidity and of the motor mount plate probably focuses the stress there.
    84 200x
