Results 1 to 7 of 7
Thread: Using synthetic oil in rear diff ok?
    unclejemima is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2009
    Canada
    197
    Changing the rear diff oil on my 84 YTM225DX. It calls for SAE 80 API GL-4 or SAE80W90 hypoid gear oil.
    I wanted synthetic, and all I could find was some 75-90 GL5 Synthetic gear oil from the parts store.
    Is this stuff ok to use in the rear diff?
    Does the GL4 and GL5 matter? I`m assuming the GL5 is just a new rating system.
    Thanks,
    Feb 2009
    michigan
    2,387
    go with the hypoid oil its great for that application,used in boat lower transmission
    1985 ATC 250R
    . Team Red Trike
    There's no clutch in there, just open gears............ I wouldn't sweat the synthetics in my differential....................
    Sep 2006
    Northwest Indiana
    1,893
    I agree...
    Oct 2009
    Canada
    197
    Thanks. The only reason I want to go with the synthetic is because it stays more fluid at lower temp.
    Will the 75-90 work the same as my 80-90? What do these numbers mean anyway?
    Thanks,
    We have had 75w140 full synthetic in the big reds for 2 or 3 years now with no leaks or noises
    Sep 2007
    100mi west of Chicago
    3,582
    Quote Originally Posted by unclejemima View Post
    Thanks,
    The first number is the weight of the oil when cold, the second is the weight once warmed up. You want a thinner oil on startup so it gets into tight places, and then it thickens up. At least that's how I have always understood it.
    Rob
