Thread: help 125m
    krazykane is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2009
    morrisville pa
    229
    help 125m
    ok so long story short .i buddy of mine needed some touch up on some furniture that he has .and tells me if i do it he will give me a honda 125m .so i get it home and the back wheels wont spin so i take the chain off and and they roll fine so the sprocket wont turn i think its a trans .but i have never messed with a 125m .so any pointers or suggestions .like maybe a pin or something.and yes i will post some pics in a few .maybe just take the side casing off of the right side and see what i find .lol
    Feb 2009
    morrisville pa
    229
    sorry guys its a 85 if that helps and runs pretty good
    Indiana
    104
    Is it in neutral? Sorry, had to ask...
    I would start by taking the sub-trans off and see if anything is obviously messed up in there.
    Feb 2009
    morrisville pa
    229
    well i open it up on the right side and the is a spring on the top left side facing with like a metal arm and it is broke .
    Texas
    137
    Quote Originally Posted by krazykane View Post
    Any way you can post pics?
    From your description, it sounds like the gear selector arm. It has a roller bearing on the end that fits into recesses in the gear drum. The arm can crack and break, leaving the trans stuck in gear or in between gears. If it's broke, you'll need another one. If it's just cracked, it can be welded up - I've fixed a few this way.
