Results 1 to 15 of 22
Thread: As promised, pics of my modded 110
    PA
    3,515
    I decided to drag the 110 out of the garage today and wash it. It was sitting in my shed for at least 4 years but maybe closer to 6. It cleaned up ok but I forgot that when I painted my bronco I got over spray all over the 110.
    Anyway, here are what I remember doing to it back when I built it.
    9'' gold front wheel (mid/late 80s Q-sport rear wheel some machining required)
    chrome forks with 85/86 R front fender
    panted the tank white with PPG car paint
    sanded the rear fenders and used PC1 to refinish them
    custom fender cut
    300ex seat cover
    200x axle (good amount of machining required)
    200x disc brakes (fairly straight forward)
    185 carb
    1 200x hub and 1 250x/300ex hub to get the rear wheels spaced right
    cobra pipe
    K&N filter and custom air inlet tube
    Ported head
    custom high compression piston (don't ask...lol)
    megacycle cam
    HD valve springs by R&D
    titanium retainers
    And IMO a must have on any small bike......1/2 bald 18x9.5x8 turf tamers
    I would buy used turf tamers off my buddys when I needed tires since the 1/2 bald tires are no good for large bikes and they are perfect on little bikes to get them to slide...lol
    WWW.HREATV.COM
    Feb 2009
    michigan
    2,387
    thats a nice 110.your overspray should come off,depending how far away it was when you painted the truck.
    1985 ATC 250R
    . Team Red Trike
    1,736
    pretty cool stuff.
    Nov 2009
    Okauchee, WI
    555
    That looks like some wicked good fun ridin. Nice job.
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    Nov 2007
    ulysses pa
    1,231
    i love the way this thing looks. i have one sitting i hope to do up for the lady. care to explain what kinda work gets done to fit the 200x axle? what did you do about the difference in chain sizes from the 110 front to the 200x rear?
    PA
    3,515
    Thanks guys
    I always wanted a 110 back in the 80s but back around 1982 dad bought a 1981 185s and he told me he's not buying a smaller trike...lol
    When my daughter turned 6 I seen a 1978 90 for sale near me and I rebuilt it for her but It was a pain to ride with here on my built up 350x hybrid. So after like 2 years I found the mother load of 110 parts ( enough for 3-4 complete trikes) so I built her a sweet stock 110 and I built myself this one to be able to ride with her. Well she is 19 now and dont like to ride and the other little bikes are long gone and this one just sits.
    Now that it's cleaned up I am thinking about selling it since it just sits around taking up room....I don't know.
    WWW.HREATV.COM
    PA
    3,515
    Quote Originally Posted by trizilla View Post
    The chain size was the easy part. I just bought an after market sprocket from Dennis kirk which has a mostly solid center to it. I machined the sprocket center hole to fit on the 200x sprocket hub and that let me use the stock size chain. To get that sprocket to line up right I had to thin down the 200x sprocket hub on a lathe. Then the one rear tire stuck out farther then the other so thats why I run the offset hub on one side. I also used tapper bearings inside the stock carrier which took more lathe work.
    For those who don't know,tapper bearing (just like the ones used in front hubs on cars) are WAY stronger then ball bearings and have next to no rolling resistance. You no longer use the bearing pipe spacer thing that is normally between the stock bearings. And you just basically hand tighten your first axle nut, then tighten the 2nd nut to the first to hold it in place. Nothing rolls as nice as properly setup tapper bearings.
    Edit...... on second thought I might of only opened up the center hole of the rear sprocket slightly. I think I machined the 200x sprocket hub to have a step or a ledge for the 110 sprocket to fit over....I cant remeber and I'd have to tear it down to be sure of what I really did.
    WWW.HREATV.COM
    Just like trucks use to have, like your Bronco; Superior bearings!
    Nice 110 bud!!
    May 2009
    Minnesota
    457
    Sweet little ride!
    1982 Honda Big Red 200e
    1985 Honda 200x- sold
    1986 Honda 125m- sold
    1986 Honda Big Red 250es
    1986 Honda 250sx
    mike1979 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    Michigan
    406
    I used a product called "Oops" got it at the hardware store, just rubs it with a towel and the paint will come right off, wont harm the plastics either. I actually had to remove paint from spray painted fenders so a little overspray should be no big deal
    PA
    3,515
    Quote Originally Posted by mike1979 View Post
    thanks but, I wonder what it will do to the PC1 on the rear fenders.
    The front frnders got it the worst and they are painted so I'm kinda limited as what I can do. I'm not to worried about it, it has been like that for atleast 5 years.
    WWW.HREATV.COM
    Lancaster, PA
    1,738
    its about time you get that out and cleaned
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    PA
    3,515
    I got to tell you guys, i just rode the 110 in the yard for 20 min and it is a freaking ball to ride!
    My shoulder is feeling OK so i figured I'd try to start it and ride it back to the shed instead of pushing it. Keep in mind it sat for years and only ran 1 time this year for a few minuets. I pulled it 2 times and it was running! It did smoke pretty good till the motor warmed up but it did seem to stop once it got up to temp.
    Then my daughter jumped on it and rode it around smiling and laughing as she went. She begged me not to banish it to the shed and to keep it in the garage but I need the room and HATE scraping ice off my broncos windshield. She even broke out her phone and took a short video of me riding it (without me knowing she did it) but I had no helmet on so I can post it here.
    I guess I kinda hijacked my own thread but it did bring back some old fun memory's. I just wanted to let you guys know it REALLY runs great in this cold December air (might be jetted to rich for the summer) and it hauled my nearly 300 pound butt around like I was on a much larger trike. The front end WILL and does come off the ground in a hurry every time you speed shift it...lol
    With all that said, it is still for sale but I wont be upset if no one wants it.
    I just posted this in the classified thread in my for sale add. I just wanted to post this up since I noticed a few threads asking about modding newer 110s.
    WWW.HREATV.COM
    Aug 2007
    Burlington maine
    652
    IMO you need a front # plate. Looks nice.
    1987 Honda 200X 90% way through frame up.
    1987 CR500R Motor, Soon to be a 540 ATC motor
    1986 250R frame, For now
    2008 Honda 700XX
    2004 KFX700 Torque monster!
    2011 Can-Am Commander 1000X
    Looking for misc Liquid R parts
    PA
    3,515
    Funny thing is, I have one for it but I never bothered to put it on.
    Here's a pic of it from YEARS ago.
    WWW.HREATV.COM
