Results 1 to 15 of 17
Thread: My home built Big Red plow... Lots of pics...
    Oct 2007
    Minneapolis mn
    4,067
    I have gotten quite a few request on the plow I built for my BR, so I decided to write it up out in the open for all to see... I started out with a CL score of a 46" wide plow from a garden tractor. I believe I paid 40 bucks for it, and it had the swivel. Laid it out in fron of the BR, and found it to fit just right... I used 1.5" square tubing (3/16th" wall thickness) for my frame work. --Picture 3 is the basic frame work of the plow. --Pic 4 was the first part I built. Its the cross bar that is underneath my engine, both of the dog ears drop in behind the pegs, using the peg bolts. (has gone an entire winter of plowing alot of driveways without any issues) This bar is 28" wide and has a 3/4" coupling nuts welded into each end. (welded around the end, and then plug welds through the tube on all 4 sides for extra security)
    --Pic 5 and 6 are the right side of this bar. Notice that there is a notch in the tube for rear brake lever clearance.
    --Picture seven is primarily the shape of the mounting tab on the left side peg mount. (nut welded in...)
    --Picture 8 is a 3/4 inch bolt with a shoulder that measure just a tiny bit over 1.5". So this conveniently bottoms out in the ends of this under bar and makes for a good beefy pivot point.
    Please excuse the rust... I must have forgotten to wash all the MN salt off before I packed it away for the summer. DOH!!
    I used Duplicolor Bedliner in the rattler for paint, and neglected to scuff down the metal, so its flaking off like dandruff...
    Attached Thumbnails Attached Thumbnails 023.jpg   025.jpg   006.jpg   001.jpg   002.jpg   005.jpg
    Oct 2007
    Minneapolis mn
    4,067
    Here the pic shows the pivot point, and the overall peremiter design of the frame. From the end of the pivot point, to the front edge of the pivot point bar, is 40" even. (if I were to do this over, I would have made this length more like 41.5" long) The angles cut into the 1.5" square tubes are 35 degrees each, making the total angle of each side 70 degrees from straight. I have been using a Superwinch 2000 lbs winch to power the plow up and down. The downside to this is when the plow is up in the air, you are fighting the winch cable a bit, but I dont find it to be bad... When the plow is on the ground, it steers normal... (for a trike!) Its late here, (well late enough that my kids are in bed, so I am not going to pull the BR out and mount it up tonight, but will take a few more pics of it going into place, and get them posted as well... f anyone has more specific questions, just ask, and I will answer them the best I can... Total investment, 85 bucks for the winch, 40 for the plow and 15 bucks into metal and hardware... $140.00 total for a fun way to move snow!
    I was laid off at the time from my fabrication job. If I was to do it over, I would have made it out of round tubing on the hydro bender, but didnt have money, or axcess to one at the time...
    May 2009
    Minnesota
    457
    Sweet, wish I had an ES to build one for...
    1982 Honda Big Red 200e
    1985 Honda 200x- sold
    1986 Honda 125m- sold
    1986 Honda Big Red 250es
    1986 Honda 250sx
    Woodsrider's Avatar
    Woodsrider is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2009
    Eastern Passage, NS
    238
    Wow..thanks for that..I want to make one this fall...thanks again for sharing !!
    Feb 2009
    michigan
    2,387
    nice job on the fab work,and it sure beats a shovel
    1985 ATC 250R
    . Team Red Trike
    Pacific NW
    4,255
    Man, that is beautiful.
    I wonder if there's a way to make/use a drag blade, like the way a farm tractor works.
    If you ran the blade at an angle so it would 'self-unload' or I wonder if it would just make the rear end drift sideways and just do artistic doughnuts.
    I've got a bunch of dirt coming from a new bus station in town and I guess we'll pull out anything we have that runs to try and level and grade it all.
    Thinking I could start with a heavy old pickuptruck bumper.
    hmmmm
    Thanks for the inspiration.
    Apr 2010
    Holland, Michigan
    46
    thanks for the help man, hopefully i can get started on this soon...winter will be here all too soon.
    Nov 2009
    Okauchee, WI
    555
    Looks great. I've been thinking of building a plow for my 250es since I got it. Just gotta find a decently priced plow with the pivot assembly. My neighbors think I'm crazy as it is. But if they saw me on the lake plowing the ice skating rink on my Big Red they'd really think I got some good stuff.
    Thanks for the pics of your set-up. I know there's been some interest in seeing it.
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    Nov 2006
    Huffman TX
    891
    Dang nice ES, wish I could find one for sale(in my range)
    TRIKES
    1987 200x -First Trike-
    82 185s-SOLD!
    82 250r-SOLD!
    85 250es -the lil red hulk
    Quote Originally Posted by Midnite_rider View Post
    I like the outlook..... It ran fine before it broke!!!! it was flying before it exploded!!!! it was like new until I tore it up!!!!! LOL She was a virgin until last night??????
    ustin666 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2009
    moncton
    237
    nice ss rime
    Terryville,CT
    1,616
    That is great! and i have seen someone plow an oval track with a big red at raffas house with a car stereo on there! cant remember who it was but it was great!
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    Oct 2007
    Minneapolis mn
    4,067
    Thanks guys... I love the look I get in the neigborhood pushing the blade around with my BR... I am just wrapping up my new front rack/winch plate for the front end. Was getting a little hard on my nice original rack, so I cut up a POS rack and did a little reinforcing! Will get a pic or two up once I get it finished...
    OHIO
    2,857
    Quote Originally Posted by Thorpe View Post
    Interested to see front winch mount???? My arm gets a litttle tired on my 200 when I plow.....I have used springs to assist but they take a bit to much pressure off. Let me know what type of rollers, winch etc... you use. My neighbors always slow down when big red is blasting the snow as well...... lol Trailpros and all!!
    Dec 2010
    quakertown pa
    13
    nice trike man. n good job on the plow build. im goin to make one for my 200x. hows it steer with the blade down?
    85' 200x
    87' TRX310R
    03' JB Racing crf450/400ex hybrid
    Oct 2007
    Minneapolis mn
    4,067
    With the blade down it steers really easy...
    With the blade angled, it doesnt drift the rear around....
    Heres the "beefed" up rack... May install a few speed holes to take down some of the bulky look... (yes those are foot prints, I was standing on it...)
ID:	114427Click image for larger version.
ID:	114428Click image for larger version.
