Results 1 to 15 of 51
Thread: Yamahondaman BILLET ESTATE SALE ! Sale is live! Tons of billet aluminum and stainless
    Billy Golightly's Avatar
    Live Oak, FL
    15,049
    • 0 Tri-Z 3 way Thermostat Delete coolers Aluminum. Sold OUT!
    • 20 250R Radiator grommet sleeves. Aluminum. $10 for each set of 2.
    • 3 sets of 2, Tri-Z & Banshee axle caps. Aluminum. $15 for each set of 2.
    • 16 Tri-Z swingarm bolt Nuts & Washers (Just the nut and the washer, no bolt!) Stainless. $10 for each nut & washer combo.
    • 2 sets of 2, 350X Front pivot inserts. Stainless. $15 per set.
    • 2 250R pivot inserts. Stainless.
    • 3 sets of 2, Banshee Pivot Caps. Stainless. $15 per set.
    • 0 sets of 2, Tri-Z/Banshee axle nuts. Stainless. $20 per set. Sold OUT!
    • 6 250R front axle sleeves. Stainless. $20 each.
    • 2 sets of 2, 350X swingarm pivot cap. Stainless. $15 per set.
    • 0 85-86 250R footpeg bolts (Stainless, do not recommend for anything other than show use. Stainless is very hard and brittle for shearing strength and there is a likely chance they would break off and completely lose a peg under even light use). Sold OUT!.
    • 7 sets of 2, 1/4in wide 250R axle spacers. Stainless. $5 per set.
    • 8 sets of 2, 3/4in wide 250R axle spacers. Stainless. $5 per set.
    • 5 86-87 T3 Front axle hub sleeves. Aluminum. $20 each
    • 4 86-87 T3 Front axle seal sleeves/spacers. Stainless. $15 for 2
    • 0 83-84 ATC250R swingarm bolts. Stainless. $50 each Sold OUT!
    • 0 86-87 T3 front axle. Stainless $50 Each Sold OUT!
    • 1 86-87 T3 Pivot Bolts. Stainless. $50 Each
    • 1 83-85 200X Swingarm bolts. Stainless. $50 Each
    • 8 Tri-Z front axles. Stainless. $50 Each
    • 4 84-85 T3 Swingarm Bolts. Stainless $50 Each
    • 0 250R 85-86 & 350X front axles. Stainless. $50 Each Sold Out!
    • 3 350X swingarm bolts. Stainless. $50 Each
    • 2 86-87 200x Swingarm Bolts. Stainless. $50 Each
    • 0 86-87 200x Front Axles. Stainless. Sold OUT!
    • 5 sets of 4 85-87 TRX/ATC250R front pivot caps. Stainless. $20 per set of 4
    • 0 Exhaust sleeves. Stepped internally with o-rings. Tapered outside. Very nice. I don't know what they fit, but its probably worth a gamble. Might be Tri-Z Aluminum. Sold OUT!
    • 2 sets of 2, one inch wide 85-86 250R axle/hub spacers. Stainless. $5 per set of 2
    • 10 sets of 4, 250R footpeg bolt washers. THICK! Stainless. $15 per set of 4
    • 0 sets of 2, 83-84 T3 Fork Caps. Aluminum. $20 per set of 2 Sold OUT!
    • 2 sets of 2, 83-84 250R front pivot inserts. Stainless.
    • 2 85 T3 front axle tube spacer. Aluminum.
    • 4 250R front axle spacers, Short ones. Aluminum. Sold OUT!
    • 3 sets of 2 1986 200X pivot washers, 14MM ID. $10 per set
    PRICES ARE NON-NEGOTIABLE!
    I DONT HAVE ANYTHING THAT ISN"T LISTED!
    PAYPAL ONLY! hondaatc@gmail.com
    Send as a GIFT, with name and quantities of what you want. Please include "Ronnie" or "Yamahondaman" somewhere in the subject of the paypal. Stuff will be sold in the order which the paypal is received. Its possible I will sell out of stuff before I'm able to update it on the list here. If I do I will refund you.
    Also, Please include your shipping address in the comments! When you send as a gift, it does not show up for me!
    I'm shipping in the $5 flat rate envelopes. Whatever I can fit in one will ship for $5. Whatever I can't will go into another one, and so on. 2 swingarm bolts or 2 axles and a handful of other little stuff will fit in one. Anything more than that, figure on another $5.
Name:	SDC15545 (Custom).JPG
ID:	108405Click image for larger version.
Name:	SDC15527 (Custom).JPG
ID:	108402Click image for larger version.
Name:	SDC15542 (Custom).JPG
ID:	108399Click image for larger version.
Name:	SDC15554 (Custom).JPG
ID:	108415Click image for larger version.
Name:	SDC15534 (Custom).JPG
ID:	108412Click image for larger version.
Name:	SDC15544 (Custom).JPG
ID:	108409Click image for larger version.
Name:	SDC15566 (Custom).JPG
ID:	108406Click image for larger version.
Name:	SDC15535 (Custom).JPG
ID:	108403Click image for larger version.
Name:	SDC15557 (Custom).JPG
ID:	108400Click image for larger version.
Name:	SDC15543 (Custom).JPG
ID:	108416Click image for larger version.
Name:	SDC15536 (Custom).JPG
ID:	108397Click image for larger version.
Name:	SDC15540 (Custom).JPG
ID:	108413Click image for larger version.
Name:	SDC15539 (Custom).JPG
ID:	108410Click image for larger version.
Name:	SDC15556 (Custom).JPG
ID:	108407Click image for larger version.
Name:	SDC15541 (Custom).JPG
ID:	108404Click image for larger version.
Name:	SDC15504 (Custom).JPG
ID:	108401Click image for larger version.
Name:	SDC15528 (Custom).JPG
ID:	108398Click image for larger version.
Name:	SDC15565 (Custom).JPG
ID:	108414Click image for larger version.
Name:	SDC15522 (Custom).JPG
ID:	108411Click image for larger version.
Name:	SDC15519 (Custom).JPG
    Sold 4 250R/350X front axles leaving 3 remaining.
    Sold 1 83-84 250R swingarm bolt. 6 remaining.
    Sold 1 83-85 250R swingarm bolt. 5 remaining.
    Sold 2 sets of 84-85 T3 Fork caps. 2 Remaining.
    Sold 4 250R short front axle/hub spacers. Sold out!
    Sold one mystery exhaust sleeve, 3 remaining. 1 set of Tri-Z Banshee Axle nuts, 1 remaining.
    Sold one Tri-Z thermostat Delete 3 way cooler, 5 remaining.
    Sold 1 250R/350X stainless front axle. 2 remaining.
    Sold 1 set of 250R pivot caps, 5 remaining.
    Sold 1 set of 250R stainless foot peg bolts, Sold OUT!
    Sold 1 set of 250R footpeg washers, 10 sets remaining
    Sold 1 set of 84-85 T3 Fork Caps. 1 remaining
    Sold 1 86-87 T3 Front axle. 1 remaining.
    Sold 1 86-87 T3 Swingarm bolt. 2 remaining.
    Sold 1 set of 86-87 T3 axle spacers. 4 remaining.
    Sold 1 set of 84-86 T3 Fork Caps. Sold Out!
    Sold 1 set of Tri-Z/Banshee axle nuts. Sold OUT!
    Sold 1 Tri-Z 3way thermostat delete cooler. 4 remaining
    Sold 1 mystery exhaust sleeve. 2 remaining.
    Sold 1 83-85 200X Swingarm bolt. 5 remaining.
    Sold 1 set of 2 350X pivot inserts, 2 remaining.
    Sold 1 set of 2 350X swinger caps, 3 remaining.
    Sold 1 86-87 200X swingarm bolt, 2 remaining.
    Sold 1 86-87 200X front axle, 1 remaining.
    Sold 1 set of 86-87 200X pivot washers, 3 remaining.
    Sold 1 83-85 200X Swingarm bolt. 4 remaining.
    Sold 1 set of 350X Pivot caps, 2 remaining.
    Sold 1 83-85 200X swingarm bolt, 3 remaining.
    Sold 1 Tri-Z Thermostat delete cooler, 3 remaining.
    Sold 1 86-87 T3 Pivot bolt, ONE REMAINING!
    Sold 1 86-87 T3 front axle, Sold OUT!
    Sold 3 T-stat eliminators Sold OUT!
    Sold 2 Mystery Exhaust clamps Sold OUT!
    Sold 1 83 85 200X swingarm bolt, one remaining.
    Sold remaining 83-84 250R swingarm bolts. Sold OUT!
    One can only beat their head up against the wall so often before they get blood in their eyes.
    Note to members: Stupidity is a BANABLE offense, mods can decide if YOU are being stupid and WILL ban you!
    Sep 2008
    845 New York
    2,302
    awsome.will be looking for the air fooler bolts and tri z stuff.let me know when prices are up.
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    Raleigh, nc
    71
    I DEFINITELY want a 83 250r swingarm bolt. Maybe 2!
    84 200s
    83 250R
    84 ATC110
    85 ATC110
    84 YTM200
    85 YTM225DX
    ATCT is offline Just Too Addicted Arm chair racerJust too addicted
    Dec 2005
    Phoenix, AZ
    709
    I'll take an 83-84 250R swingarm bolt. Would be good to have a spare just in case.
    1984 Honda ATC250R
    laidout2times is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2007
    SOUTH OF HEAVEN
    180
    Ill take an 83/4 swinger bolt and 86 t-3 axle and bolts... Let me know what addy to paypal and how many envelopes youll need.
    Thanks
    Aug 2009
    Chesterfield, Virginia
    845
    I would take one or two T3 swing arm bolts, I'll keep my eyes open for your listing
    TRIKE INTERESTS
    A1/A2 TECATE's
    BIKE INTERESTS
    ATK, Husqvarna, Maico, Harley Davidson & Yamaha Twins
    PLEASE KEEP AN EYE OUT FOR THE FOLLOWING STOLEN 3/30/2012
    1999 ATK 260LQ ENG# 425681 Red/White/Blue VIN# 4MAV1CC43XA009376 (Its the last one missing out of four the first three were destroyed)
    My Feedback
    May 2008
    Tenn
    547
    PM sent on the Z t stat.
    Just-Tri-It
    :Trikes Owned:
    1985 Tri-z's 3
    1986 Tri-z
    1984 YTM 200ERN 1
    Live Oak, FL
    15,049
    I've just finished inventorying the first box. I will do the second one tomorrow hopefully, and try and work together a price on some stuff.
    Nightmare's Avatar
    Nightmare is offline At The Back Of The Pack Arm chair racerFirst time rider
    lehigh valley, PA
    196
    Interested in 86-87 200x stuff. Cant wait.
    WNY
    517
    I'll take a TRI-Z oil filler cap and maybe the thermostat cooler. The cooler just eliminates the t-stat?
    85 Big Red 250ES
    01 Scrambler 90 (Sons')
    Past Machines:
    96 Yamaha V-Max 600, 86 200x, 84 200es, 82 70, 82 200, 03 Bombardier DS650, 93 Ski-doo Formula Plus, 87 Ski-doo Stratos, 83 Yamaha XT550, 82 Kawasaki KDX175. 84 Tecate, 86 Tri-Z, 91 CR250.
    hondawasaki's Avatar
    hondawasaki is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    Murray, UT
    319
    count me on a T3 swingarm bolt, and ft axle bolt. Thanks
    Apr 2003
    Central New York
    1,860
    Billy,
    P.M. sent for parts
    86-87 200x front axle
    dust caps, bearing puller
    Thank you.
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    Live Oak, FL
    15,049
    Guys I'm getting PMs left and right. I don't really want to "reserve" or hold stuff for people. My plan is to finish inventorying. I will post pictures of some of the stuff and then a day or two later I will post the complete inventory with price list and it'll be first come first serve via who I received paypal from. There is just so much stuff (I've got a full page worth of stuff already and I'm maybe 1/2 way through it) That is going to be the only way possible for me to keep up with it, and Its not fair for me to hold stuff for people when there is cash buyers ready and available. I will try and schedule the posting of the list and prices sometime over the weekend where everyone has the opportunity to be on the computer and get their purchases in.
    Aug 2005
    Lockport, NY
    2,399
    I was fortunate to recieve a swinger bolt and front axle for my 86 t3 project right before Ronnie passed. They are top notch quality as his stuff always was.
    Nov 2009
    Ontario
    4
    interested in a 83\84 swing arm bolt let me know the price and the pay pal info
