IDK what your counter bore is for?? I know I read your reasoning, I just forget....
I milled the helll off my 06 swinger and I'm just using an inner seal to keep crap out of there. The stainless thrust washers are about 1/32nd or 1/16th thick, I forget......
Make your pics bigger will ya!
EDIT - OK, I just read your reasoning. Unless the chain alignment is an issue, the thrust washer is the buffer between the aluminum and the frame. My thrust washers mount next to the material I milled off, and are supported by the inner bearing sleeve but there is nothing wrong with the way your doing it. The thrust washers will have a smaller OD the way your doing it.........
