Vmax Xt 600 , new track and pick's last year,Reverse,,, cleaning up sweet for a 96!
looks sweet. i cant justify buying one though,would love to but not really worth it..
1985 Quad Killer
1985 Mini Raag
1985 Green Gobbin X2!!
1990 Kawasaki 300sx
R.I.P
Looks good for a 14 year old sled! Too bad its a Yammi! lol, JK
My brother in law had that same sled except no reverse back in 98 or so. He really liked it. Still regrets getting rid of it to this day
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
got the front end all fixed up,, and bead blasted the pipe.. and a nice coat of 500* paint....
I think i have a Set of Dual stage boysen reeds for that thing somewhere!!....Lookin GOOD!!
1985 Tri-Z-
Originally Posted by mywifeknowseverything
LOL, I was expecting a 2 wheeled street bike. I'd love to try one of those things on of these days, they look like a blast to ride but around here it hards to justify owning a 4X4 truck.
I serviced the carbs today.. it already has them...but if you got another set hollar.. the dude I got it from had the new track SO TIGHT it would slow down ,, like you jammin on the brake..now I know why the guy gave me 4 wooped belts!! LOL..got it all back together today and runs mint..gonna get some new camoplast ski's for it and a few small oem parts..whoot..
IM not sure about Yammi's specs, but my Doos call for 1 3/16 to 1 3/8 inch sag between the track clip and bottom of the slide, with 17lbs of downward force, centered between the rear idlers and the 1st idler on the rail near where the rails arc upward. I would guess that Yammi would work good with a similar tension setting....
Also, the previous owner may have been running the track that tight due to a clearance issue between the studs and heat exchangers in the tunnel. Make sure there are tunnel protectors if applicable and that the studs cant contact the tunnel or heat exhchangers when the track balloons out at high speed...
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
I had that same sled except mine wasnt an XT. Check the primary clutch. That could be causing the blown belts. Mine would eat a brand-new belt in a couple hours. I went through both clutches and adjusted them and then it was fine. It was a good sled although it sucked gas bad and the front suspension sucks. I mounted a rear skid out of a 1998 Ski-doo Mach-Z in mine and it increased the ride by a ton.
85 Big Red 250ES
01 Scrambler 90 (Sons')
Past Machines:
96 Yamaha V-Max 600, 86 200x, 84 200es, 82 70, 82 200, 03 Bombardier DS650, 93 Ski-doo Formula Plus, 87 Ski-doo Stratos, 83 Yamaha XT550, 82 Kawasaki KDX175. 84 Tecate, 86 Tri-Z, 91 CR250.
got it all back together..
very nice sled man!
nice sled, I had a 94 Vmax 500 2 years ago, bought for $500 and rode it for 800+ miles and sold it that spring for $700, sled ran like a top and always started on 1st pull cold/warm, the only thing is the pogo stick front steering/suspension isn't the best
Looks great! I always liked the blue on the XT's. How much did you pick it up for if ya dont mind?
85 Big Red 250ES
Past Machines:
i still ride a 92 vmax4 also has xtra10 & 1-1/4 track im gona rejet & put some 800 pipes on it this winter shes not a ditch banger but im to old for that any more i just love holdin her wfo across a lake really gets the ticker pumpin you got a nice lookin sled there man those engines are pretty bulit proof
" think I won't "
