I considered trying to adapt a set of 250R or Tri Z rear plastics to get black fenders, but was afraid the rear kick would interfere with the fenders. Any one seen a set on a tecate?
nstyle73
"When in doubt, wind it out"
Feedback: http://www.3wheelerworld.com/showthr...k-for-nstyle73
I started this past weekend, started in about 3 kicks, died then started in another 5 or so and then just died. It only ran for about 10 seconds at a really fast idle. I tried kicking it more and didn't have any luck so i pulled the plug and it looked great as it barely ran long enough to get it dirty even, so I checked for spark while I had the plug out and I had spark on the first kick, but none after that. I initially figured that the pilot jet in the carb could have something in it as the tank had been drained and then refilled after I put a petcock kit on it, but looks like it could be a spark issue. What was the big benefit of the KX250 ignition? If its going to cause me problems, I'll just put a stock setup on it. The wiring looks a bit suspect on the kill switch part as both the stock kill switch and some other momentary kill switch are both tied into the wiring with those press type connectors. JUUUUUUNNKKKKK..... I also swapped the 36mm Mikuni from my other bike because I really wanted to ride in the snow and couldn't get it started either, so looks like time to sort out the wiring.
nstyle73
Disconnected the jerry-rigged electrics and cleaned the connections and the spark was back. The wiring doesn't match any diagrams in the KX manual, so I'm not sure what it is actually from, but it works. The carb is accumulating crap out of the tank and needs a good cleaning as cleaning the pilot jet would get it fired up for a few seconds.
nstyle73
I pulled the flywheel off of my other T3 to check the timing as I've been having kickstarter problems. It is shown in the second pic with the single timing mark on the stator plate. So I pulled the flywheel off of this one to see where it was set at for reference. It has three marks and looks to be advanced according to the T3 manual, but I don't believe it to be a T3 stator. The cdi and stator don't match a KX250 wiring diagram completely either, as it has: W/R, B/Y, B/W, and W/G wires coming from the stator. I think I'm going to set it back to the T3 mark shown in the Kawasaki manual rather than the KX250 mark shown in the Clymer manual. Also, I assume the flywheel on the right is stock and the one on the left is a Ricky Stator perhaps? The right one came off of this bike.
nstyle73
I set the timing backto the center mark, pulled the varnished TM38 and put an old Keihin PWK38 on in place of it, and it started on the second kick and idled great. The PWK has a 178 main in it as a starting place after I took the 190 out that was in my R. The needle, pilot and airscrew will probably all need tweaked, so I took the stock airbox apart so that I could just use a filter and not have to put the airbox on/off for every jetting change. Lots of little things eating up time, like a leaking kickstart seal, exhaust leak, etc.
The only real visual progress has concerned the rear fenders. I stripped the white paint, sanded the tops and applied some "250R" type number plates. You can still see the white that will be hidden under the seat, and a little bit on the underside that I need finish cleaning up. Not too bad for being white. Just can't wait for the Cosmic Quads seat cover to get here.
nstyle73
I put the fenders off of my other bike on so that I could ride in the snow. I finally got some pilot jets, so I think I need to move from a 42 down to a 40. Everywhere else the bike seems to run pretty well, but I"m sure jetting is just starting. I also put on the "flat track" tires the previous owner included. I thought maybe it was a real race bike and had real flat track tires, like Hoosiers or something, but when he pulled them out of the garage, I thought......'at leas the rims look nice' I had to swap on a 14/35 gear set to compensate for the 18" tires. The bike is set up with the forks slid up through the triples about 3" and the rear lower, and with the 18" tires on there, its about 4-5" shorter than my other T3. It looks pretty nice wide and low, but the stock front tire is just too tall for my taste. I think a 10" rim like in the Mad Scientists Lair may be necessary. All of the body work needs clear coated and fastened on still.
nstyle73
It looks awesome, but i'd put a black seat cover on it!!
If it ain't sideways......what's the point!!
86' Honda Atc 250R - under restoration
10' Polaris Outlaw 525s - my XC race quad
05' ATK 640 "Cannondale" xc racer
00' Banshee 350
LOL, yeah, I'm waiting for the seat to get here, the fenders AND seat are off of my other bike. The blue does look dumb.
nstyle73
Man nstyle73, you have 2 killer Tecates. The latest is really neat with how you have it set up. To cool.
looking good man.. what kind of pipe is that...my tank covers will be here tomorrow... i started tearing mine down tonight cant wait to get started with my build....
82 ATC 250R (AS $ Crusher.. Project 450 swinger)
84 ATC 200X (Project Blackout) Hers
86 ATC 250R
86 TRX 250R (The Golfcart)
87 CBR 1000F SSSA STREET FIGHTER
95 NINJA 250EX
My Feedback http://www.3wheelerworld.com/showthr...-Rollingmenace
Thanks for the compliments. The monster one is kind of rough, but I thought I would ride it harder that way. The pipe is just a stock one that I painted with ceramic paint. I'll see how it holds up.
nstyle73
I have my PWK38 on the bike right now with a 178 main and a 40 pilot and the TM38 that came off of the bike has the following specs:
Needle: 6FJ41 (I thought it said 6FJ47, but I can't find that needle listed anywhere)
Clip in 3rd notch down
Throttle Valve (Cutaway in the JWR): 4.0
Float Needle Valve: 3.5
Main: 370
Pilot: 40
I took a look at the JWReplica manual, but don't really know if its worth trying to replicate since its for the 85 bike. Right now I think I'll stick with what was in the TM38 maybe unless something really looks out of place to someone. It took a lot of cleaning and new jets to get it respectable. Hopefully it runs when I put the carb back on.
nstyle73
I figured out what the slop in the rear axle carrier was finally. It was missing the special washer that is relieved on the ID to fit over the splines for the brake rotor hub. I found one I had for a T4 and put it on and it took up the slack. I bolted on some peg extensions and worked on the shrouds some more. A head gun, utility knife and some sandpaper have the triples hitting the stops without hitting the shrouds. Next up is further jetting, bleeding the rear brakes and waiting on a seat. The seat/fenders and airbox should make it look a lot better.
nstyle73
Looks killer!
I got the seat back from Tammy at Cosmic Quads and it looks great. I'm putting rings in it right now and putting a stock stator set up that I had jeswinehart lighten and work his magic on. My headlight shroud will be a welded up OEM piece painted black to match the rest of the bike. I put the TM38 on with a 35 Pilot, 370 main and I think it needs richened up in the mid to top. I put one of those cheap tach/hour meters on to help with tuning and keep track of maintenance. It seems to need a clutch and is doggy on the very bottom with good mid-bottom range and great mid-top and top end. The cylinder is stock with no porting and the bore is 70mm. I'm going to put a reed spacer and a set of reeds in it when I put it back together.
nstyle73
