Page 1 of 11 1 2 3 ... LastLast
Results 1 to 15 of 151
Thread: rotax 399 in a hard tail
    osoyoos bc canada
    1,057
    i got a motor belt and jack shaft from a 70 skidoo tnt the sled was crazy fast on grass but the track ripped in half and i got a trimoto 175 frame with the front cradle cut out
    i was thinking about building a bad @$$ hard tail manly for ripping on flat gravle roads
    has anyone tryed this id like to see pics of a similar set up before i even start if anyone has any
    osoyoos bc canada
    1,057
    basicly this and this
    osoyoos bc canada
    1,057
    except my stuff is crap
    OK
    5,450
    Quote Originally Posted by bcredneck View Post
    I find that hard to believe... I kid, I kid..
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    osoyoos bc canada
    1,057
    i had the spedo on the sled in the 90s before it broke dont know if it was accurate but if the trike has a 3rd of the weight it should go faster than you would want to go on a hard tail personally i think thats a good thing
    Gold Hill, OR
    1,295
    Yeah 24hp, must have been a rocket
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
    osoyoos bc canada
    1,057
    the tnt was 30 hp because the tnt had a diferent carb than a normal 399 it revs up to 10000 rpm many grassdrag sleds have used this motor with moded headers
    osoyoos bc canada
    1,057
    on sleds one pully get bigger the other gets smaller as the rmps go up basicaly a fully auto tranny i love this setup its also tuneable so i can make it hit top speed right in the powerband
    osoyoos bc canada
    1,057
    a rotax 399 is one of there rarest motors this would be good if i sold it but bad when i brake it
    osoyoos bc canada
    1,057
    a brand new crf 450 has 43 hp so it has less power but it has a has a higher top speed on the sled
    Xfile's Avatar
    Xfile is offline Just Too Addicted Arm chair racerJust too addicted
    Apr 2007
    Shiocton, Wisconsin
    700
    10G with breaker point ignition?
    Don't worry...just run watcha brung...
    OK
    5,450
    Not to mention that the YT doesn't have a front cradle. The motor is under the seat mostly.
    Rides:
    My feedback thread
    Lauderdale County, Alabama
    2,029
    And the fact that due to carrying three massive chunks of something that makes boulders look like Jenny Craig, you're probably going to top out at about 25 mph with the 399.
    I really, REALLY, really, wouldnt even try to put THAT in THERE(yes, that IS what she said). I think you're trying to show me up on the whole deathtrap ideas.
    osoyoos bc canada
    1,057
    iv actualy been planing this for a long time and yes it has points i put much stronger springs when i rebuilt the motor 3 years ago if you think it will only go 25mph youve been smoking some thing look on youtube and see what these motors are capable of on a 450lb sled it dosent mater that the front cradle of the frame is gone its going to be rebiult with square tubing to fit the motor ive seen dune buggy with a 340 go fast let alone a 399 in a striped down trike its not going to be a death trap eather
    the motor and the rear end both have brakes and it wont be intendid fo rough roads just for running flat out on graded roads
    osoyoos bc canada
    1,057
    whats holding the front of the motor in then look at the pic i posted the only trikes that dont have lay down motors edit:sorry i didnt see the pastic covering the frame ill find a differnt pic
