Results 1 to 15 of 30
Thread: Deadly poison gas from welding something you cleaned with brakleen?
    Pacific NW
    4,255
    Saw it on ford-trucks.com
    14 ppmillion is enough to kill,
    tetra whatever turns into a one shot deal
    What an easy mistake to make.
    May 2007
    Orange County, NY !
    1,673
    Pacific NW
    4,255
    Nice find riverrat.
    That should cover it.
    Thanks
    Aug 2007
    Moab, UT
    1,807
    A contestant for the Darwin awards.
    Lauderdale County, Alabama
    2,029
    indeed, but I do feel sorry for the guy, one little slip up.
    Nov 2010
    Coos Bay, Oregon, United States
    254
    Is it the same with the chlorinated and non-chlorinated? I tend to stick with the non-flammable non-chlorinated just to prevent fire issues.
    mine: 85 Honda 350x
    http://www.Jeep4PlayOffroad.org
    WNY
    517
    Holy crap! He's lucky.
    85 Big Red 250ES
    01 Scrambler 90 (Sons')
    Past Machines:
    96 Yamaha V-Max 600, 86 200x, 84 200es, 82 70, 82 200, 03 Bombardier DS650, 93 Ski-doo Formula Plus, 87 Ski-doo Stratos, 83 Yamaha XT550, 82 Kawasaki KDX175. 84 Tecate, 86 Tri-Z, 91 CR250.
    Holy crap! That is a mistake I could easily make! Thanks a lot for posting this Dr. Joe.
    swifty's Avatar
    swifty is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    sabula iowa
    381
    wow thats scary im sure ive welded in the past with brakleened stuff but my old welder didnt have argon. good post saved me from ever using brakleen for welding projects again
    ACT NOW THINK LATER!
    current trikes owned
    minty 86 250sx my rider
    pauter flat track framed 110-123cc with custom goodies
    pauter mx framed 110-123cc with aftermarket goodies
    joker framed 90-108cc with front suspension
    2007 artic cat DVX 400
    dickson sprint framed 73 green us90 with 110 engine
    I basically swim in (have been for 25 years) brake/carb cleaner, actetone, lacquer thinner, WD40, PB blaster etc. I've never worn gloves and I'm sure I've heated a part that had brake cleaner on it. The other day I was torching red off my frame and it hit the paint stripper; MAN was that a horrible smell!!!!!!!!!!!!
    Dec 2009
    the ville illinois
    477
    Its scary to think about all the stuff we've exposed ourselfs to out in the garage!
    Quote Originally Posted by racer....X View Post
    As long as it's not the neighborhood kids you'll be OK.
    Sep 2007
    100mi west of Chicago
    3,582
    Stacey on the Gearz show on Speed Channel mentioned this before
    Rob
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Phosgene is bad stuff...I always use carb cleaner before I weld stuff.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by tri again View Post
    Saw it on ford-trucks.com 14 ppmillion is enough to kill, tetra whatever turns into a one shot deal
    Hello tri again
    Just thought I’d add some additional info to this topic to help clear some things up for you and any others that are interested in it.
    Quote Originally Posted by bugler30 View Post
    No.
    AIR LEAK TESTS, BRAKE CLEANER AND PHOSGENE
    If one feels it necessary to do an air leak test one suggestion is to test by gently spraying [using the long narrow nozzle] FLAMMABLE [not water base or chlorinated] brake cleaner around the intake boot at the head and carb mount while the bike is idling. If the idle goes up noticeably you have an intake air leak. It is more volatile than flammable carb cleaner and therefore detects small leaks more easily.
    I still use brake cleaner but only the flammable kind [since I don’t see much point in spraying non flammable substances into a motor to check for an intake leak], just don’t spray it on ex pipes anyway and be careful NOT to inhale fumes of ANY cleaners. Flammable Carburetor cleaner may produce more harmful fumes than NON chlorinated flammable brake cleaner however I don’t know, further research is needed by someone to determine this if one wants to know.
    Here’s one type of chlorinated [no tetrachloroethylene], flammable brake cleaner one can use when testing for intake leaks without the fear of creating phosgene.
    http://www.crcindustries.com/ei/prod....aspx?id=05084
    With it idling, spray some carb cleaner around where the carb mounts and see if it changes the idle. do NOT use brakleen, it burns into phosgene gas and can kill you.
    [QUOTE=tri again;1227182]Hi Not sure I read everything correctly but I remember a thread about using brakleen to clean stuff that will be torched or welded. I personally can't seem to live without it.Apparently it turns into phosgene gas in the presence of flame which can cause permanent lung damage with the smallest of exposure. I've heard that carb cleaner can work to check for intake leaks but not sure about that either. I read the can after I read that article and the warning is very vague.
    Flame is not required to break down tetrachloroethylene to a point at which it will produce a very small percentage of phosogene as a byproduct only heat is.
    Thermal decomposition of Tetrachloroethylene creates phosgene ie heat + UV + TCE => some phosgene.
    “Tetrachloroethylene began to decompose near 400°C and vigorous pyrolysis occurred over 600°C. Complete decomposition was observed at 800°C. Hydrogen chloride and phosgene were detected as decomposition products, presumably because chemical reaction occurs between tetrachloroethylene and water contained in tetrachloroethylene.
    Chemosphere
    Volume 26, Issue 8, April 1993, Pages 1507-1512”
    Tetrachloroethylene is NON flammable and is used in NON flammable CHLORINATED brake cleaner.
    Flammable brake cleaners are NON chlorinated [no tetrachloroethylene].
