Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: Honda ATC 110 Transmision Has No First Gear
    WJG1000W is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2012
    Amana Iowa
    184
    i just checked mine and it is supposed to have a pin in that empty hole
    Mar 2011
    Orange County N.Y.
    15
    Yes I do have a manual for it but that doesnt help me. Ok thats what I thought, it seemed odd that there was only one pin. What does that piece actually do? I know it is right against the clutch but I dont get what it actually does. Thanks
    Dec 2011
    Ontario, Canada
    509
    Quote Originally Posted by jbizub5192 View Post
    Oh thanks for telling me that!! I wouldn't have dont that lol
    you would have done it, just in a different way lol
    Trikes
    83' atc 110
    83' atc 200e
    84' atc 200m
    84' atc 200x
    85' atc 200x
    86' P3
    Non ATC
    2002 blaster sorry lol
    Mar 2011
    Orange County N.Y.
    15
    Does anyone have any ideas on what could be causing no first gear? Thanks
    Mar 2011
    Orange County N.Y.
    15
    Quote Originally Posted by JJMF1979 View Post
    True lol, It woud have been very messy
    Pacific NW
    4,255
    Attachment 143259 On the center of clutch where that metal piece is there is 2 drilled holes on that metal piece. One hole has a bolt/pin through it, the other is just a empty hole. Should it be like that?
    That is just the coolest oddball, cam action semi rotational offset wobble piece I've ever seen.
    I bet it really does need both rivets. because of it's eccentric rotational nature.
    I'll go look, I have one apart but I need boots and a snowsuit to go outside.
    oh
    the words service manual
    should light up and get you to the world class help section for a free manual.
    If not, just go there and snag one
    Mar 2011
    Orange County N.Y.
    15
    Thanks for the help! I looked in the manual but I cant really make it out. Its hard to tell from the picture. But could that part really be causing me not to have first gear? All the other gears work fine. Thanks!
    Mar 2012
    Amana Iowa
    184
    check the gears inside the transmission also
    Mar 2011
    Orange County N.Y.
    15
    I would have to pull the engine and trans out for that though right?
    Howdy's Avatar
    Celina, Ohio
    10,079
    To check the internal gears you will have to do a complete motor tear down. If your not very confident in doing this then you might want to have someone else do it for you or find another motor. I say this because there is a lot of parts to deal with in the inside.
    Howdy
