Page 1 of 6 1 2 3 ... LastLast
Results 1 to 15 of 88
Thread: bw80 to atc70 conversion.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    i finally had a little time to convert this bw 80 front suspension to fit a atc70,, i added a 70 tire so it wouldn't be so tall and still look more oem,,, i just won another bw front off ebay without a tire so i think i will do one with the 10" original tire too,, oh yeah i built some 2.5" bar risers for it too,,,
    nova scotia
    125
    post some pics with them mounted
    Ripley Tn
    1,363
    this is a good idea
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
    honda4h's Avatar
    honda4h is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    ottawa ontario
    361
    do the forks bolt on? or is there more to it?
    osoyoos bc canada
    1,057
    is that 70 going to have rear suspention to
    KASEY's Avatar
    4,250
    THE STEERING STEMS ARE TOTALLY DIFFERENT SIZE AND LENGTH. i had to remove the old stem and weld the 70 stem in the lower triple clamp. the front hub is atc and the sleeves had to be cut down ,, i don't think a stock tire will fit inbetween the forks , the tire i have is a little narrower than stock,, i am going to builkd a complete full suspension rolling chassis that will be for sale when its done..
    scottyms's Avatar
    scottyms is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2006
    I've been contemplating this same swap... i plan to cut the head tube out of the bw frame and put it on the 70 chasis, i figure its got to get stretched a few inches anyway... i'll be keeping up on this one...
    scotty
    current line up:
    86 KXT250 Tecate
    87 KXT250 Tecate
    86 ATC350X
    87 ATC200X
    85 YTM200
    and about a dozen more in parts...
    KASEY's Avatar
    4,250
    the problem with swapping the head tube,, its alot shorter than an ATC .. then the gastank comes into play for top and bottom clearance . thats why A+ stayed with an atc neck to avoid that problem,, now if you strech the frame out you might be able to get away with it,
    Ripley Tn
    1,363
    kasey i want dibs on this frame when it comes up for sale
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    KASEY's Avatar
    4,250
    lol!!!!! i supose you want to pick all the colors and accessories too??? :-)
    I've had the parts laying around for along time to do this swap but never got around to doing Keep us posted inqiring mind want to know
    Ripley Tn
    1,363
    black lots of black and a turbo would b a nice touch ape hanger's haha goin to look good
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    KASEY's Avatar
    4,250
    since there is a little interest i will profile this build up. i picked up a beater pitbike, i am going to use the frame for this one, ita a typical chinese pitbike, nothing special, this won't be mine . it probably will end up in the kids garage when its done ,, this won't be an all out build either, it will be a more budget type build,, here are a few starting picts,, notice the totally different steering head angles? i will cut the neck off the pitbike frame and strech it 2 inches,, i will cut all the mounts and brackets off to while i am at it. since i already have a 70 neck cut off it will be easy to get it setup too,,, by the way i have a very nice motor out of the pit bike its only 50cc's but it runs great all the crap off the pit bike is for sale CHEAP,,,
    Ripley Tn
    1,363
    this is neat
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    bloomsbury nj,08804
    117
    Kasey: I'm interested in the pit bike parts, I noticed on your profile you don't receive pm's so if you could email me pictures (easier than making a list) and kill two birds with one stone that'd be great. elliotrepko13@hotmail.com <--- and fyi noo, I not 13y old
