Wow the fenders shape looks like new other than it needs a little paint lol
The paint will be next. I also finished my steel front fender and it too is ready for paint. I need to sandblast my headlight housing and all of the red parts will be ready to paint. I found some paint that was a very close match to the tank I'm using. I'm not going to paint the tank. The original paint is too nice to mess with.
Appalachian American Racing
the home of
New computer is driving me nuts. I'll try to post up some new pictures. I got some more goodies for it today.
the home of
Got my forks today!
the home of
Another pic. I likemy old puter better.
the home of
Wow nice set of PCCC forks . Look like they will clean up really nice .
Here are a few more pics of the progress so far. I'm using my old computer. I still haven't fully figured out my new one. I can't post more than one pic at a time with it so far.
Here is the front fender when I got it.
the home of
Here it is in the repair stage.
the home of
Here are some pics of the fenders in primer. They just need a final sanding and and paint at this point.
the home of
I have most of the parts I need to start mocking this project up. I still need wheels and tires. I have some from a donor but they are not what I will be using on the final product. I have more pics to come. Stay tuned.
the home of
Good stuff . I really like these threads and keep the pics comming .
the fender repair is cool nice work gonna be a cool build
85 Atc 70
86 Atc 125m
85 atc 350x
86 atc 250r
86 Atc 250r TT build
85 Big Red bought brand NEW
2012 Honda Goldwing Gl1800
Looking Good!!!!!!!!!! Great find on the forks. Got a tap bit broken in the head up in the exhaust stud hole in my new project. NOT FUN. Its been to two machine shops this week no one can get it out. Gona be in the shop all day till it comes out. So much for a ride today.
I have an almost fool proof way to remove broken studs without drilling or tapping and this eliminates the possibility of breaking off drill bits, easyouts and taps in the holes. I've even used this process to remove broken drill bits, easyouts and taps that have been broken off trying repair broken studs and bolts.
I use a mig welder to build up enough material so that I can get a good bite on it with a Good pair of vice-grips. As soon as I get it built up I put the vice-grips on it and start turning them back and forth. You sometimes have to start in very small l increments until the bolt or whatever starts to move more freely. I've had the weld break off many times until I finally got it moving. Over the years I have a success rate of over 99%. The heat from the weld loosens up the bolt, stud or whatever enough to get it out. I've even removed taps, etc. that were broken off below the surface.
the home of
Ya no luck today. I will try that on Tuesday thank you for the info. This motor is fresh and have a lot of $$$$ in it. I was only cleaning the threads and it snapped. Thanks again for the info thats all i got left to try at this point.
