Results 1 to 15 of 17
Thread: Ram Steering Stabilizer
    Nov 2002
    Connecticut
    76
    Dose anybody have some pics of a Ram steering stabilizer installed on a 85-86R. I found a couple of them upstairs in my stuff and its been years that i put on one. I would like to put it on my 85R build. Any help would be great. Thanks Glenn
    plymouth,il
    1,231
    I can't find pics but it should mound up on the bottom of the triple tree and then under the gastank somewhere. you probably already know all this though
    hope this helps
    Life is better on 3 wheels
    1984 200es big red
    1976 suzuki rm125
    1983 honda 250r (minty fresh) SOLD
    1986 honda 350x (A PILE....for now)
    197? honda 90 (pauter framed little beast in the making)
    OK
    5,450
    Quote Originally Posted by HONDA_ATC_FREAK View Post
    hope this helps
    hahahaha oh man... that one made my night.. thanks for the help..
    One end bolts to the head stay on the rh side, the other end uses the r/h rear front fender bolt. You also have to trim part of the r/h radiator cowling on the inside.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    861
    I'd be interested in seeing that installed and using one if there is any advantage to it. Thanks
    ]1986 ATC 330R
    Ohio
    593
    This is the volkswagon hood lift basically? I've been thinking about one of these. Let me know how it works!
    Nov 2002
    Connecticut
    76
    Thanks Guys, The problem I think I have is I'm trying to use it with a short track set up and I cant see that it will clear at total lock. Ill play around with it and let you know. As far as the ram it is a steering stabilizer off a VW not a hood lift if I remember right. I might play around with making a kit with the new ram that is used on the quads today it is half the size. Thanks Glenn
    Lancaster, PA
    1,738
    here are some pics I had in my files from 3ww...not my bike just reference pics. I have used these type of stabilzers on quads and they are from a VW Steering. Hope this helps
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Sweden
    20
    Good god Julle, that is TRICK!
    acidburn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Cornwall
    344
    its like the powersteering atv of the 80s lol
    OK
    5,450
    I'm going to have to agree.. very niiice.. fill us in..
    Rides:
    My feedback thread
    Sweden
    20
    Thanx! I like it, much more stabile now. Its adjustable in 7 steps from soft to hard as hell.
    861
    Yeah thanks. Is there really a advantage to using it on a trike
    ]1986 ATC 330R
    Sweden
    20
    Its a cheepo Ebay stabilizeer, 110mm stroke(perfect for the wide 81-82 tripple) and 7 steps adjust and its rebuildable. Forkclamp is 2 fatbarclamps put together and bored out to 30mm. Welded a mount to the steering head.
    Sweden
    20
    Quote Originally Posted by pantera1975 View Post
    In ruff terrain it helps a lot on my 82 to keep it going straight. But the 82 dont have the suspention like a 86 so you might not need one but it looks really cool that was enuff for me really.
