Been a long time since I had a motor burn coolant. Anybody give me a detailed explanation of what a plug should look like when it is burning coolant?
http://www.pilotodyssey.com/PO/index.php
88 TRX LRD,39MM pwk,Durablue+4.Nice rider
85 250r West Coast +4,Durablue +4,Boyesen rad valve,Keihin 39mm,Rad double row carrier
86 250R west coast +4,Durablue+4,Maier plasitcs, Keihin, Boyesen,Wiseco big bore kit
85 350x-all new everthing,trailer queen,all OEM-NOT FOR SALE!!
4-FL400R HONDA PILOTS.See my section on the page!
2-85 T-3 Tecates all the bells and whistles
85 T-3 project trike in works
Pull your spark plug. If it looks absolutely brand new, even though its been in there for a while, you've got a sign of a coolant leak into the cylinder. It's being steam cleaned everytime you run the engine.
(That info was from a different site, no first-hand experience)
THANK YOU. Mine is coming out greyish black like it is running rich. Not clean like new for sure. Even long wide open run same. Thanks again.
Are you sure its burning the coolant? It might pass through seals and go in the tranny oil.
1985 ATC250sx
1984 ATC200s
1984 ATC200x
HONDAS FOR LIFE!!!
No, I was not sure. I did have a water pump impeller seal leak due to a pitted shaft on the impeller but I changed it out. I also changed out the head and installed a new gasket as well due to a slight leak on that(exterior) to insure I had covered all bases. I still have residual coolant coming out with the oil but I changed it 3 times and each time it appeared to come out cleaner. I cannot say for sure the impeller seal leak is fixed as the residual coolant in the bottom end makes the oil cloudy, not milky, but cloudy. I did drain the oil and let it sit to see if the motor was causing it to foam, but it did not clear up after an hr of sitting. I am using Valvoline 10w 40 no synthetic.It was raining hard here yesterday so I could not take the Tecate out for a plug chop, I just idled it and some slight 1/4 throttle which sucks. Heres a picture of the oil, it has since cleared up alittle
That picture is before impeller shaft and head replacement-forgot to mention. The oil is coming out a lot clearer but still cloudy. OH, BTW motor is a fresh rebuild Tecate 85 T-3 with fresh jug, everything soup to nuts.
