Results 1 to 15 of 17
Thread: 350X Goki starter install
    Mar 2009
    Springfield, IL
    31
    I have a new starter kit from Goki for my 350X engine. I am finally clear of work enough to begin the install.
    Anyone got any tips to make the install go smoother?
    Cave Rider's Avatar
    Cave Rider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Howes Cave NY
    320
    Make sure your decomp. works properly..It may have just been my machine,but it wouldnt crank it over very well unless i slightly operated the kicker and engaged the decomp. Also,if you have to sweat on the ring gear,do not freeze/chill the flywheel, i found room temp worked best,because the cold shock would cool down the ring gear so fast it wouldnt go on easily. Otherwise,it was pretty straight forward. Good luck man !!!
    NICE QUAD !! WHY THE EXTRA WHEEL ???
    Mar 2009
    Springfield, IL
    31
    ok thanks. How did you get the flywheel out? the puller just will not bring it off the crank. The clutch keeps slipping.
    NEPA
    7,051
    You need an impact to work on these.
    OK
    5,450
    I don't know if this will help but there is some install help at the bottom. The pictures have gone the way of the buffalo but the write up is still there.
    http://www.3wheeler.org/vb/showthrea...x+goki+install
    Here is Jim's Goki install.. his came out super sano..
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Mar 2009
    Springfield, IL
    31
    great thanks all. impact with a little tapping on the tool then it popped off. now working on pressing ring gear on. not all the way on so gonna work on it more tomorrow.
    Mar 2009
    Springfield, IL
    31
    looks like there still is a small gap on the ring. Is this normal? I can not squeeze it down any further the studs have stripped. Also, i am missing the wire shield.
    Finger Lakes Region, NY
    613
    Wish I could help with your questions but thought I would share that my 85 350X has the Goki Starter, it was installed when I bought it. You might want to use a higher amp battery if you can fit it. Like mentioned above, I push down my kick start lever just enough to engage the decompression then it turns it right over nice. I love it! Greatest option yet for us older folks with arthritis! Mine has the Honda 250ES light/on/off/starter switch that looks nice, just push the start button like the Big Red! Some people think I'm telling stories when I tell them I own a 350X with electric start! Be sure to use a case saver, Tim
    ...the branch cannot bear fruit of itself, unless it abide in the vine...
    OK
    5,450
    I like how FlyingW used his parking brake to attach it to the decompression so you don't have to fiddle with your kickstarter.. I really like the battery in the airbox so you don't have to attach a battery box. If you have any questions pm FlyingW at 3wheeler.org..
    Rides:
    My feedback thread
    Cave Rider's Avatar
    Nov 2010
    Howes Cave NY
    320
    Since there is no "like" button,i will write it.... LIKE
    Mar 2009
    Springfield, IL
    31
    1. Goki sent the missing part overnight and thanks to them for responding so quickly.
    2. I have completed the install, except for the battery I will attempt to start today.
    Mar 2009
    Springfield, IL
    31
    Got it working and starts the bike. But the gear shifter sticks down or up depending on the shift.
    Dec 2010
    845
    You should make a video of starting it I've never seen a goki starter actually work
    Mar 2009
    Springfield, IL
    31
    The starter motor spring/gear broke when i tested at the track. Goki shipped overnight a replacement and I will test out again this week.
    NEPA
    7,051
    I'm not too impressed here! These should come out of the box,and START the machine! Not,,fiddle w the decompressor... I have a kit for each year tucked away,one was going in the 472,,,guess I'll save my time! I'm glad to hear they're taking care of your parts,,,but darn....
