Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: Honda 200s vs 185s power?
    Trikeboss's Avatar
    Trikeboss is offline At The Back Of The Pack Arm chair racerFirst time rider
    Duluth Minnesnowta
    166
    I picked up the 1981 185s framed 200 today! I think it was setup to ice race It's fast compared to the 110 thats for sure ...This thing is a little beast! ...it came with new cheng shin? tires on it and the brakes are great. Its the tightest riding trike I have ever ridden...no shakes,smoke, wabbles or noises or vibes ect...Only issuse is it does not want to idle, It needs a little thumb to idle... not sure why but it could just be the idle screw?
    1982 HONDA ATC 185s
    1982 HONDA ATC 110
    ontario
    1,131
    they are pretty close to the same , the difference would amount to the history and care given to each, I would probably go with the 83 the little bit of front susp. is nice and racks are real handy , they did make a 185 that had 9 inch wheels 1980-81 not a s model was bigger frame and tires , also shifted down instead of up , you could always put a 200x top end and carb aftermarket exhoust to get more power..
    I believe the heads are different. The 200X does not have a decompresser and it was a higher compression ratio (9.6 to 1) the 185 is (8.0 to 1). So if you just put a 200x topend on it you wouldn't be able to pull it over you would having to bumb start it and most likly you would have to redue your clutch to hold the power.
    Just to bring it back up the 185 may be alittle fast then the 200cc bike because all the 200cc expect the 200x all have lower compression ratio then the 185s. 200cc have (7.6 to 1)compression ratio
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    pcs's Avatar
    pcs is offline Just Too Addicted Arm chair racerJust too addicted
    Jan 2011
    yuma, az
    465
    http://www.3wheelerworld.com/oldsite...00atc185sF.jpg
    the 185 has 8:1 c/r and is 180cc. the 200 has 7.8:1 c/r and is 192cc. the 185s is quicker because the frame was shorter and has about 30lbs less to carry around so it was quicker. many parts will swap between the 185/200s,x,xr200. the xr 200 piston has a bit more compression and makes the engine a 198cc vs the other 200 atcs that are 192cc. the cam on the 200x and xr200 have more lift that the 185/200s with the xr having the most.
    Team Blue: 85 Tri-z 250: under the knife
    Team Red: 87 Trx250r 01Cr80 15 CBR600RR
    Team Yellow: 06 Ltr450 11 Hayabusa
    Trikeboss's Avatar
    Duluth Minnesnowta
    166
    So thats why this thing feels kinda quick!...its a 200s engine in a 185s frame...Its a stout little beast...I may be keeping this one for a little while
    1982 HONDA ATC 185s
    1982 HONDA ATC 110
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    Yes - in 1980 the BIG HOSS trike was the ATC185 (non S model) It was big - the same size as the 1981- 1983 ATC200 (also non-S models)- 25" tires and larger frame than the later model 1981-1983 ATC185S (which is the same size as a 1984 - 1986 ATC200S)
    Basically here is how it went:
    1980 - ATC185 = large
    1981 - 1982 ATC200 = large
    1981 - 1982 ATC185S = smaller
    1983 - ATC200 = large - update with front suspension
    1983 - ATC185S = smaller - update with front suspension
    1984 - 1986 ATC200S= smaller (no more larger model)
    The 185 motor made slightly more horsepower (like less than 1 more HP) but the 200 made more torque. Any comparison made after about 1990 would not be very good considering worn out motors and parts. I have had very fast and very slow 185 and 200 models - depending on how abused they were. I currently have a very low hour ATC185 and it has good power - btu the gearing is higher, so my ATC185S feels faster. Weight difference in machines is minimal
    ATC200 ATC185 = Approx 299#
    ATC185S ATC200S = Approx 270#
    Now with only 12 - 14 HP - you have to take rider weight into consideration - also tires are a factor, a big heavy Trail-Pro will be much more weight to turn than a stock knobby.
    I have a semi custom 185 and deal with a lot of 185 and 200 parts bikes and never really could keep all the differences straight. That is the best quick summary I have ever read. I think I may print that and hang it over the work bench till I get it in memory. Thanks!
    FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
    86 250R
    86 350X
    87 250sx
    85 200x/cb350 custom
    81 185s/200x/250r custom
    79 atc 70
    Mini-Trail z50, 110cc Pit Bike
    and many multi-wheeled machines
    Dec 2010
    washington state
    681
    that was very interesting ,and yes the 185 witha 200x head is a bump start ,start on the hill and park on the hill so starting downhill but it is fast .the pullstart will work but you gotta be ready for it also breacks the rope pretty reguler
    GOT MUD?:
    Ironbnder's Avatar
    Alexandria, La
    363
    Quote Originally Posted by 350XJEDI View Post
    Why is this? Is the 200x head so smaller cc's that it bumps the compression up that high? I thought the chamber was about the same, just no decompression device. I have never used the decompression lever on any pull start trike. I am not understanding the difficulty in pull roping a 185/200x engine.
    86 250R
    86 350X
    87 250sx
    79 atc 70
    ontario
    1,131
    Yes the heads are the same other then the decompresser but its the pistion that makes the diffrence the X was a (9.6 to 1) compression ratio and all the others 200cc have (7,6 to 1) compression ratio, I rebuild the topend on my x last year and it had 175 psi compreesion dry. This was with a stock pistion and new rings.
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    Aug 2011
    Oceanside, CA
    1984 ATC 185s & 200s differences...
    When I was a kid (the was in 1982-1986) my neighbor had a 185s and I had a 125m. I just picked up a nice 200s and i've become a fanatic/expert on these bikes. Here is a complete list of the main differences in 1983:
    Engine size: 185s 180cc - 200s 192cc
    Compression ratio: 185s 8:1 - 200s 7.8:1
    Length: 185s 67.7" - 200s 72.4"
    Width: 185s 39.4" - 200s 42.5"
    Height: 185s 38.5" - 200s 39.6"
    Wheelbase: 185s 44.1" - 200s 46.9"
    Seat height: 185s 26.2" - 200s 272"
    Ground clearance: 185s 4.7" - 200s 4.9"
    Tires: 185s 22x11.8 - 200s 25x12.8
    Dry weight: 185s 270.1 - 200s 299.9
    Horsepower: 185s 13@5,500rpm - 200s 13.5@7000rpm
    Torque (ft-lbs): 185s 9.26@5,500rpm - 200s 11@6000 rpm
    bloomsbury nj,08804
    117
    I had asked this very same question a while ago and no one answered me I've got the answer i was looking for now. and if I may side track the conversation for a bit; I know it's kinda vague how do yo think my bike Klt 185 compares against the competition in stock for stock engine performance judging by the data sheets given?
    Displacement 182cc
    Bore x Stroke 66 x 53.2 mm
    Compression ratio 9.5 to 1
    bloomsbury nj,08804
    117
    If i get help answering my question....I won't have to ask it again....ever!
    tapage is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2012
    Montrose, IA U.S.A.
    166
    I have a 200es and a 185s and the little will blow away 360 prairies that have 150lb people on them and i weigh in at around 300, still my 185 has had the rings ate out of it and smokes worse then my cousin and i feel unstoppable when im on it...
    May 2003
    Houston, Texas
    2,409
    1980 ATC 185 (hot rod of its day for sure)
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    Nov 2006
    Tulare, California
    719
    Quote Originally Posted by three_wheelin45 View Post
    lol its a 200s and a 185s not really a big woot which goes faster...
    LMAO!!! Hahaha I know huh... there both little pingers... But yeah my dads first trike after like 25 years was a 200s.. I rode it but can only compare it to my old 200x. The bikes run good, I think I rode a 185 before.. You would think the 200s would get up a bit faster..
    Current Bike:
    1985 Honda 350X
    Bikes owned:
    1984 Honda 200X
    1982 Honda 250R
    1985 Honda 350X x3
    1985 Honda 250R x2
    1985 Honda 500X
  15. #30
    Zach's Avatar
    Zach is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    Enumclaw, Wa
    262
    always go with the cleaner machine if they are priced the same engine mods are easy on these things, its replaceing the broken and or missing stuff that will kill your wallet.
    1986 350x
    1985 250es Big Red
    1985 200m - sold
    1984 225dx - sold
    JCPenny Scat Tracker
    1977 atc 90
    2002 custom Suzuki Volusia
    1983 XL250R
    1975 XL175 (needs alot of work)
    1965 S90
    Proud Owner of 1 Set of Trailpros
