Results 1 to 15 of 25
Thread: What were the best years for the 200x?
    Mar 2011
    Ohio
    236
    I read on here awhile back that the later models are worth more than the earlier models and that they're better for some reason. I'm looking at a couple 1985's and wondered what you guys could tell me about them. They both don't run and the owner wants $450 for both.
    Jan 2011
    Brazil, Indiana
    2,087
    86 & 87 are the better years as far as desirability and power. 87's are almost non existent with only a very small ammount getting released. You cant go wrong with getting two for $450
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Mar 2011
    Ohio
    236
    What changed from 85 to 86 that gave it more power?
    dksix's Avatar
    dksix is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2010
    North East Tennessee, USA
    610
    The 2nd gen was a completely different engine and had a 6 speed tranny.
    Finger Lakes Region, NY
    613
    I believe the 85 and under had the crank seating different than the 86 and 87. I'm not very mechanical but to my understanding after being shown a split case the 86 and up have some type of sleeves or bearings that is much better than previous years where the crank rests in the case. Someone more knowledgeable can probably explain it better but I believe the intent was to extend the life of the case etc.
    ...the branch cannot bear fruit of itself, unless it abide in the vine...
    Lauderdale County, Alabama
    2,029
    I've owned both generations. Two different animals, second gen had a better tranny, better, stronger, even bigger displacement engine, with a completely different design(seriously, the valve adjustment is CRAZY!), better swingarms, better suspension, better kickers, better everything IMHO.
    Better lookin' too. Even the frames are different, the second gen frames are squared IIRC. I've got one as a deco piece in m shop, I should be able to remembeer that.
    NEPA
    7,051
    2 completely different machines. 86-7 are square framed,6 speeds,Much more comftorable,far smoother. Superior chain adjustment,,on and on !! Having said that,,1st gens are awesome too!! An 84 was my 1st "sport" ATC. Pounded her relentlessly,,bent axles were all it ever cost me. great machines..
    Pacific NW
    4,255
    I think mine was an early model.
    Very fun but there are extensive posts about kick start gears,
    Since they have manual clutch, easier to jumpstart
    and if they're tuned correctly, they should start 1/2 kick anyway.
    450 for 2 sounds good.
    Kick each starter a few times to make sure they don't slip or hang down,
    reasonable tires, compression, not rotted gas tanks and I'd get them for sure.
    Unless I'm forgetting some catastrophic deal killer specific to the x.
    One model has a nightmare swing arm bolt issue but that may be the 'r' 2 stroke models.
    ametzker's Avatar
    ametzker is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oregon
    170
    Tippman 98 I see your also an International Harvester man. I've got a a 200x and an IH Scout 800. Seems there are certain types of people drawn to same hobbies. = ) For the record I have an 85 200x and am happy with it.
    Williamstown PA
    5,825
    83-85 had chain adjusters on swingarm. 86-87 had ecentric (sp) carrier in swingarm adjustment like new atvs. ive had many 83-85s. cheap fun bikes but kicker issues came up with everyone i owned and axles are junk on 83-85...they are my fav style but not worth much in my mind anymore...too many issues they always have later down the road and oem axles are not made anymore lol.
    Crest California
    3,014
    My personal opinion is for you to get a first gen 200x. There's THOUSANDS of things you can do to them, and the best part is you can get a good one for cheap. You can get a POS and restore it back to original, or you can make it a solid running beater. Take a good one and trick it out, or inject nitrous into it's blood to make it a full blown race machine. The skies the limit.
    The best part is that you're not hurting anything by taking a run of the mill first gen 200x and doing whatever you want to it. The second gens I tend to think of as the trikes that should be kept in good condition and not beated on, because there's not a whole lot of them left out there.
    I know the second gens have more power and a 6 speed tranny, but the same year XR200R engines have 6 speed gearboxes, and they literally bolt right in. I hat a hot XR200R engine that's been stroked out that I sold to a member here and he ran it in his 200X. The only issue is that the kickstarter is rear kick, but looking at the engines, I'd bet that you could slip on a rear kick mechanism relatively easy. I think it's just the side covers that have the reverse gears...
    LED obsessed
    2015 Yamaha FJ-09
    Dec 2009
    Timewell, IL
    100
    Are the aftermarket parts available for the second gen as they are the first? If you wanted to build a racer which would be the easiest to find aftermarket parts for?
    NEPA
    7,051
    Neither would be easy. 2nd gen,almost non existant..
    Bustos82's Avatar
    Bustos82 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2011
    Coolidge, Arizona
    447
    have an 84 200x and love that thing....
    A veteran is someone who, at one point in his life wrote a blank check Made payable to 'The United States of America' for an amount of 'up to and including my life.' That is Honor, and there are too many people in this country who no longer understand it.
    Mountain Home, AR 72653
    500
    Buy them and send me pictures........ I would be interested in just one for $300 if it were fully intact.
