Alright, to be honest I have done this before and I know that there are a few threads on here to restore fenders already. I took several pictures through out the process and can tell you what I used.
Step one: I scraped the oxidation off the fender.
Step two: I rubbed it down with fine steel wool.
Step three: I dry sanded it with 320 grit, 400 grit, then 1500 grit.
Step four: I wet sanded in the same order as above.
Step five: I took the blue brillo pad and car polish then when over the entire fender.
Step six: I removed the polish and then used the 1500 grit and the polish again.
Step seven: Removed the polish and hit it with Armor All.
It should be easy to guess, but which one is the NOS, and which one is the redone?
Trikes Currently Owned:
