Results 1 to 13 of 13
Thread: Lifted my 1985 Big Red
    69-ss-396's Avatar
    69-ss-396 is offline At The Back Of The Pack Arm chair racerFirst time rider
    NC
    184
    Lifted the front 3" and the rear 2". Lift is pretty simple.. For the front I Cut some 1 1/2 Tube 3" Long slit the bottom so the fork tubes would slide in, welded some flat bar to it drilled a couple holes and bolted them together.. Holds the forks nice and tight and I tested them out yesterday!! The rear I cut some flat bar 4" and drilled a couple holes 2" apart.. Wheels are 12X7 Condor 7 spoke. Front is a 5+2 offset with a 2" spacer rear are 2+5 With a 2" spacer.. Running 27" essex sure foot..
    Attached Thumbnails Attached Thumbnails br rear lift.JPG   85br.JPG   br fork lift.JPG   br fork lift1.JPG   85br1.JPG
    200 is offline First Time Rider Arm chair racerNew to the board
    Jun 2011
    Wow man looks badass. I was planing on doing that to my 85 250 BR do you have any pointers or tips?
    Oct 2006
    Titusville, FL.
    631
    Wow bro you didn't waste any time! Looks real good! My front lift looks just like that, but after a year of riding there is alot of slop where the fork tubes slide in!
    Sarnia, Ontario, Canada
    3,415
    Cool idea and I'd love to do it, but won't the sharper angle on the driveshaft stress the u-joints and possibilily cause failure??
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    chuckiedog04's Avatar
    chuckiedog04 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2011
    minnesota
    369
    would you please get a close up of your rear end lift? and the front end lift closeup?
    69-ss-396's Avatar
    NC
    184
    Mondexbrute I based mine off your lift.. The shaft angle does not worry me at this point I dont feel any vibrations.. If I run into trouble down the road with it I will let you guys know..
    69-ss-396's Avatar
    NC
    184
    Here is a pic of the front
    Sep 2011
    Barrie Ontario
    38
    I too would like a couple mores pics of the rear lift.
    1984 200x
    1985 200m
    1984 200s
    3,415
    I like it..just I would have stayed an even 2" front and rear.
    Looks a bit 'chopper' in the front for my taste..
    Still worried about the increase driveshaft angle..let us know how that works out for you and whether the thing starts eating drive shafts.
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Mar 2011
    St. Paul, MN
    74
    My friend's and I all have lifted our Big Reds. Just rear lift, no front lifts yet though. I used 2 pieces of angle iron (I thin similar to what Mondexbrute did) and raised it about 2.5".
    To Dougspcs, we did hear some noise in one of the four Big Red's we lifted, but so far after a lot of use over a year, no driveshaft problems.
    Below is the only pic I have on my work computer...my BR is the closest with 25" Mud Bugs (1.25" lugs!) all around and 2.5" rear lift.
Name:	6 honda big reds.jpg
    edit:
    I found some pics on my FB account
Name:	the guys and the BRs.jpg
ID:	132469Click image for larger version.
Name:	all 7 BRs 3.jpg
ID:	132470Click image for larger version.
Name:	all 7 BRs 2.jpg
ID:	132471Click image for larger version.
Name:	all 7 BRs.jpg
ID:	132472Click image for larger version.
    __________________________________________________ ____________________________________________
    My wheelers:
    current:
    '86 Honda ATC Big Red 250es - lifted and 1.25" Mud Bugs all-around
    (2) '85 Honda ATC Big Red 250es - lifted
    previous:
    '85 Honda ATC 200s
    Nov 2009
    uk
    79
    im interested in doing this on my 85 bigred , just one question , whats it handle like ?? cheers darren
    Mar 2011
    St. Paul, MN
    74
    Quote Originally Posted by bigdarren View Post
    After we lifted our BRs, we also bought some spacers (1.5") to help offset the increased height.
    My wheelers:
    current:
    '86 Honda ATC Big Red 250es - disc brakes, lifted, spaced and 27" Super Swamper TSL / Vampire (1.22" lugs) all-around
    '86 Honda ATC 250sx - Mud Bugs (1.19" lugs) in the rear
    '85 Honda ATC 250sx - not currently running
    '85 Honda ATC Big Red 250es - runs
    previous:
    '85 Honda ATC 200s
    Oct 2009
    FF, Man.
    774
    Looks good SS!......we need some pics of your R as well. Nice stuff you got!
    My 3WW Feedback Thread:
    Salut Gilles
