Results 1 to 13 of 13
Thread: FYI: Pro-x offers a connecting rod kit for 86-87 200x
    bushwacker51 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Cherokee, Oklahoma
    267
    I am in the process of rebuilding a 1986 200x motor and discovered honda no longer offers a rod for the 86-87 200x. Vesrah offers a kit for the 83-85 200x, but not the 86-87 200x kit which is different then 83-85 200x motor. I had to call L. A. sleve who is pro-x dealer and they called the pro-x whare house and had the connecting rod kit in stock and it is being shipped to me as we speak. The pro-x part number is 03.1253. I hope this helps someone when they go looking for a 1986-87 200x rod kit. Glenn O
    6,786
    What about the NOS 86/87 vesrah kit I sent you ?
    They make kits but they are listed as 86-88 trx200 instead of 86/87 atc200x
    http://cgi.ebay.com/ebaymotors/HONDA...item1e661a0ae8
    Jun 2003
    Cherokee, Oklahoma
    267
    Well the Honda part number for a rod for the 86-88 trx 200 is different then the rod number for the 1986-87 200x motor. Vesrah does not list a connecting rod kit for the 86-87 200x. I am not an expert but differnt part numbers usually mean a differnt part. Please correct me if I am wrong. Thanks Glenn O.
    6,786
    Yep your wrong LOL . Honda's part # system wasn't designed for interchangeability between different models . The fat cat 200 , trx and the 86/87 atc200x are all basically the same motors (different starter set ups) but all the parts are going to have different part #s .
    Mic your stock rod and mic the rod I sent you and you will see that they are the same rods .
    Quote Originally Posted by bushwacker51 View Post
    Jun 2003
    Cherokee, Oklahoma
    267
    Well that shows you how much I know thanks for the information. Will all the other parts interchange also? I am looking for a new clutch basket and honda has discontinued them for the 86-87 200x. and what year fat cat 200? thanks for all your help on this matter. Glenn O.
    6,786
    Clutch basket might be different because the fatcat is auto clutch . You should be able to find a good used 86/87 200x basket on ebay?
    May 2020
    VA
    3
    hello I'm new to the page and seen this add I am also looking for an 86 atc 200x rod kit for my sons bike I bought the pro-x part number 03.1253 but it was to short and did not work. could you tell me the vesrah part number or any other rod kits that would work thanks.
    6,786
    After more research and hands on rebuilding a couple 86/87 cranks since , the only parts that I’m aware of that work are OEM Honda .
    Just keep an eye on eBay for the parts .
    Quote Originally Posted by Ppete1010 View Post
    6,786
    Their are several good used crankshafts on eBay , probably the cheapest route IMO
    https://www.ebay.com/sch/i.html?_nkw...c200x+rod+kit+
    May 2020
    VA
    3
    86 atc 200x rod kit
    I seen a couple of cranks on eBay I just wanted a fresh motor overall and didn't think that it would be this difficult to find a rod kit to fit a Honda but man its not going well. I also looked into a VA-1012 it all seemed to match except the lower pin was 1mm larger didn't know if anyone had any luck with looking at maybe having the crank pin holes machined out to fit. anything is helpful.
    I'm also looking for stock rod dimensions for the 86 atc 200x rod and cant seem to find anything anyone got anything.
    thanks
    6,786
    You can also contact crankworks and see what they have available .
    May 2020
    VA
    3
    86 atc 200x rod kit
    I will try them thanks
    Hyndman PA
    1,905
    Just seen this as I'm working on a fix to rebuild the stock cranks, I can do it now but it's $500 to do it with a new rod kit. I also build a HD rod but that runs it into the $800 range.
