Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: if you dig home made! that works!!
    Mar 2008
    EastGreenbush, newyork
    3,494
    well i made this maybe 8 months ago! was gonna do a vid of it when i got it all buttoned up and pc'ed, but with the recent threads on tire changing being a hot topic, i couldnt hold out. wanted to share it with those who might appreciate it. I cant take credit for the design, these types have been around in some form or another. everything used was salvaged from the parts bins at work. the plate and round stock my dad gave me compliments of NYS!! the plastic cones and rim lock i did buy from the guy who produced a version for sale. i designed mine off of what i saw on his website tirestripper.com. if i had a lathe i could have made some cones. and the lock is simple enough to make i just couldnt find material thick enough and he was willing to sell me one. here's the process with pics as we go......
    the base- center post is from a universal weight machine that was crushed when a tree fell on my dads garage! bolted through the bottom. tabs welded to base to hold the 3 unistrut legs.
    9" 350x rim installed with small cone and piece imade to tighten it out of a pipe nipple and union. would like to improve this piece, but it works! large cone is for larger hub openings. 25 yr old original tire!!
    the breaker bar- its 1 1/4 round stock. i had a thinner one originally, and the first oem tire i tried it bent. rigid couplings and some angle i cut up and ground to shape make up the head. the welds arnt the best, but i have very little expierience, this was by far the most welding ive done. some arnt burnt in far enough, but its held fine.
    i have a schedule 80 pvc coupling pressed inside the rigid coupling for smooth rotation!!
    and then........
    Mar 2008
    3,494
    we break the bead..
    always a pleasant surprise when the slime is there!!
    now these balloon style tires are a prick, cause they want to fold over the rounded edge and the head wants to slip back. it helps to leave a bit of air in the tire. but thats fun when it pops with the slime in there. if the head was a little narrower it might help. you learn a few tricks as you use it.
    Mar 2008
    3,494
    proceeding....
    you take the tire off install the rim lock which rests against a leg to prevent the rim from spinning while trying to take the tire off. flip it reinstall and break the bead on the other side.
    the next piece of the puzzle.......
    Mar 2008
    3,494
    the mount demount bar- the square stock again compliments of nys. the 2 ends i made up of stuff from work. some angle, nuts welded into the square stock , and pieces i cut bent and ground to shape out of some large pipe hangers
    Mar 2008
    3,494
    demounting the tire-push the tire down into the dropped center of the rim on one side, hook the head under the lip of the tire. this bar is heavy, takes a bit to man handle it. not like the nice aluminum one i copied it from!
    bring the bar down over the center post and rotate around. pops right off!
    pull the tire to the top of the rim and repeat with the bottom lip.
    what a damn mess that slime makes!!
    Mar 2008
    3,494
    heres a closer look at some of the parts
    i am not mounting any tires at this time, so you will have to wait until another time to see that, maybe i will have it finished, and will make a video by then!! thanks for following, and feel free to post your thoughts good or bad!!
    Mar 2008
    3,494
    heres a link to where i got the idea.
    http://www.tirestripper.com/
    South Wales, U.K.
    525
    I like it!!
    If it ain't sideways......what's the point!!
    86' Honda Atc 250R - under restoration
    10' Polaris Outlaw 525s - my XC race quad
    05' ATK 640 "Cannondale" xc racer
    00' Banshee 350
    redskinman's Avatar
    redskinman is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2010
    Cypress,Tx
    378
    nice job
    82 250r-SOLD
    85 200x-SOLD
    85 Odyssey fl350-SOLD
    1989 Honda Pilot FL400
    1985 Yamaha 225dx
    Jan 2011
    Avon, Minnesota
    641
    and i am still using a and chisel o well mabey some day... But great job on that build
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    Williamstown PA
    5,825
    cool tool, im guessing slime doesnt dry lol
    Scootertrash's Avatar
    In the sticks
    4,638
    Nice job! Now I have a(nother) project!! this design sure beats my current bead breaker. It just breaks the bead, no feature for popping the bead off of the rim.
    Nope, slime doesn't dry. I only use it in emergencies. I'll pull a tire and patch it first.
    Mar 2008
    3,494
    thanks for the kind words guys! more than half the tires ive done with this have been slimed!! guys love the stuff!! it does work, but what a mess when the time comes to change it!!
    R-tifacts's Avatar
    R-tifacts is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    New York
    404
    I love it, very nice work man, necessity is the mother of invention ~ Plato
    Dying breed with a need for speed
    85 ATC 70
    85 250es Big Red
    85 ATC 250R
    86 ATC 350x
    86 KXT Tecate
    87 ATC 250r replica
    Buffalo, NY
    1,994
    I'm glad my tax dollars made you a bead breaker. Your welcome.
