i like to make things, and i want to start to powder so why not start right. I've had the hot coat it for almost 2 yrs now, and its still in the box!! i have a ton of projects, and not much time, but i have to start somewhere. I cant see powdering all the bits, and not the frame, and axles and any other large items you may want to do. which brings us to the oven build! It will be 3x4x6 inside dimensions. framed with 20 gauge studs, insulated with mineralwool insulation, and sheathed with galvanized sheet metal. I built the base out of 1 5/8 solid unistrut. it will be heated with roughly 10,000 watts of electric heating elements controlled by a thermostat. I have a little work to do on the frame yet, then i need to find some sheet metal. the places ive called are all aroung 45-50.00 for a 4x8 or 4x10 sheet of 22 gauge, i would rather go a bit thicker, but alot of ovens are built with less with no issues. It will have a door on the one end with a window, and temp shooting port. i will update the thread as i progress, hopefully once i get the sheet metal i will be off and running. I have almost everything i need, minus sheet metal, and i only got about 170.00 in it so far. I have to get my new compressor piped down to the basement also!! heres my progress. thanks for looking.
