Since I am a big truck junkie more than trikes, who is with me for next years rodeo. If I can shoehorn the KT in the narrow hood I might be able to
have some fun with these guys.
http://youtu.be/BVh3nueHzCo
I'm a big truck junkie too. I've been to some rodeos in California. Mostly timed course driving. I've owned Freightliners and Pete's.. I'm a Peterbilt guy for life...
Rides:
1982 ATC70 (Lifan manual 125)
1987 LT80 (piped, widened)
My feedback thread
RIP Trace.. Godspeed.
Sweet.. I restored a 62KW and love it. Have been looking for a narrow hood pete to maybe play around with but havent found any yet.
KT= HEAVY AND SLOW... i have a c-18 cat motor in the shop right now,, its 900 hp and has a warranty ,, thats at 1800 rpm,, balanced up i have seen these motors turn 2600 rpm,,,, 1500 hp is pretty easy to reach too....
My Freightliner had a Cummins and my Pete had a 425 Cat, and the Caterpillar motor was twice the motor my Cummins was.
Rides:
My feedback thread
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
Big trucks are my favorite! We have 4 mid 80's trucks that we use to haul grain, 2 extended hood Pete's, one standard Pete, and a KW W900. All were origionally equipped with sleepers; which we removed a few years ago and shortened the frames. All four of them have 3406 Cat engines and Eaton 15 speeds. That 3406 is a damn fine engine. They'll pull a 90,000lb + trailer load of beans out of a soft field at idle. Not to mention nothin' beats the sound of a 8" straight pipe on a diesel.
Nothin' beats a Pete.
1974 Honda ATC 70
1985 Honda ATC 250 ES Big Red
1986 Honda ATC 250 ES Big Red
2008 Honda Rancher 420
1983 Hustler 945-HK 6x6 - Fire Breathing 627cc V-Twin Monster
2010 Chevy Silverado 1500 4x4 LT
1983 GMC K10 Sierra Classic Suburban 6.2 Liter Diesel
My Feedback:http://www.3wheelerworld.com/showthr...-for-Stonewall
There is no Z in Diesel!!!
i work with BIG equipment.. so naturally everything is BIGGER ... we use to have 3412 cats but we bought the last 5 mechanical governor engines avalible,,, these were right at 1000 hp. so now we have to deal with the new series motors,, the c-18 is a 6 cylinder vs the 3412 v 12 ,, half as many cylinders and the same power???? think it is going to last as long?? 25,000 hours?/ HELL NO .... so now we have a 3456 twin turboed 6 cylinder 950 hp.... i have one with 6000 hours and its already showing bad signs in the oil samples,,,,, looks like cat is going backwards on dependability and realiability.... we are currently looking at cummins newest generation motors ,,,,,,,,,,,
1974 Honda ATC 70
Cummins KT600 motor
My uncle had a Cummins Big Cam 400 with KT parts Making over 700 hp in his '80 Pete
He had a switch on the dash that would change his cam timing. Black smoke/no smoke so he could run in California
My first truck ('85 Freightliner)
2nd truck ('86 Pete Extended Hood 425 Cat 15 over)
My uncles '80 Pete (He laid it over in MO after being hit by 3 time drunk driver, It's now a dump truck in MO)
Downtown Chicago
Rides:
My feedback thread
THE ONLY PARTS INTERCHANGABLE BETWEEN A BIG CAM AND A KT IS THE FUEL PUMP!! and all you have to do is setup a different cpl number in the pump to make hp! 600 hp in a big cam is pretty easy,,
th k-line engines were a larger industrial engine big cam motors were 855 ci.. whereas the kt was 1150 ci. the kt has 6 individual heads and is much larger,,, some did infact make it into trucks,, but in states like arizona they were so heavy you could be overweight on the front axle without a load,,,, but man did they have alot of torque!!!
I hear what you are saying. Not to mention all the EPA garbage costing ALOT of money industry wide in down time, repairs and parts.... Guess thats why Cat got out of the on-highway business.
If you dont mind my asking, what is it you are working on that runs those big engines?? Industrial size generators???
I saw a custom 359 Pete once that had a twin turbo Cat, 950hp v-12. It is one C.L. Werner's show trucks. (Founder and CEO of Werner Enterprise)
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
Rides:
My feedback thread
atcually cat is getting into the on-hiway big.. google ct-660 caterpillars new highway truck its in the testing phase for the class 8 truck,, but i have seen one at our cat dealer,,, they are having issues with epa controls right now ,,, but i think next year they will be out on the highways around the world,,, of course the proto type is YELLOW!!!
