Results 1 to 10 of 10
Thread: Just picked up an 85 200x!!
    Oct 2011
    Alaska
    4
    New to the "club" just picked up an 85 200x. Used to have several trikes when i was younger and saw this one sitting on the side of the road and ended up snaggin it for $175!!! I think I got a killer deal! All it needs is a clutch which i already have and where my questions begins. I downloaded a manual and am plenty mechanically inclined i was just wondering about soaking the new clutch disks?? I found a little info in other threads but couldn't get a definite yes or no answer if this is a necessary process? Either way insight on the matter would be good. And here is my new trike!
ID:	134129Click image for larger version.
ID:	134130Click image for larger version.
    85 200x
    Jan 2011
    Brazil, Indiana
    2,087
    Dang thats a heck of a deal. Mrs. Mosh can fix you a new seat cover for it, Her ahd her husband are both memders of this forum.
    On the clutches, It isnt a big deal to soak them first. I have heard people argue yes and no, but it is easy to throw them in oil before you start tearing it down. That way they are ready when you are.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Blossvale NY
    4,563
    WOW! Nice score! Looks like she mainly needs some cosmetic work. Its a good idea to pre-soak your clutch discs. When the clutches are installed, they are squeezed together pretty tightly, (im sure you are aware of this), and this makes it difficult for the oil to soak into the discs like it needs to. Let em soak in a pan of clean oil while you are disassembling and you'll be good to go. I dont believe that not soaking them is detrimental, it just can cause a little bit of excessive initial wear when you first run it.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Oct 2011
    Alaska
    4
    Thanks for the info guys!
    85 200x
    Matrix's Avatar
    Matrix is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2011
    Newton Falls, Ohio
    379
    Man I would go ape s**t if i found an 200x for 175.. im dying to get one but the only one on craiglist here is for 1500 because the guy says "They can sell all day 2500-3500" what a ..
    Blossvale NY
    4,563
    Quote Originally Posted by Matrix View Post
    If its a cherry 2nd gen 200x, in my area $1500 is about right. If its a cherry 1st gen, thats about $500 too high. Either way he's on crack to say they bring $2500-$3500.......Keep looking bro....
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Oct 2011
    Livonia, NY 14487
    wow... awesome!! I'm so jealous
    Baltimore, MD
    6,088
    Soaking your clutch discs depends on the clutch material. If you are using clutch discs that are like the original honda clutch discs, then yes, it's a must to pre soak them. If you are using a clutch disc like a barnett kevlar disc, then it's not really necessary.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Oct 2011
    Alaska
    4
    Thanks for the info guys, turns out it says to soak them for a few minutes in the directions. installed the clutch today and it went very well, except for the dang special tool needed to for the two lock-nuts. Not too big of a deal though, was able to sacrifice an old socket and grind one up to fit. A new clutch makes a heck of a big difference!!
    85 200x
    Matrix's Avatar
    Oct 2011
    Newton Falls, Ohio
    379
    You should get a vid up, i love the 200's and 350's
    Something about a 4 stroke lol.
