Results 1 to 3 of 3
Thread: Forks broke and stuck on 83 200e, any advice/ help?
    mxlj is offline New to the board Arm chair racerNew to the board
    Oct 2011
    kansas
    21
    Question Forks broke and stuck on 83 200e, any advice/ help?
    Ok the forks were bad on my 83 200e. i started to take them apart to see about rebuilding them.
    1) I got the right fork lower off with the shock still attached. But the shock is stuck in the lower. I cant seem to get the bolt off of the bottom of the lower. It spins but it is just the shock inside turning. Any ideas?
    2) On the other fork i got the lower off and the shock inside the fork is broke in two! the lower half of the shock came out of the lower ok. but most of the shock is stuck up inside the fork and i cant seem to get it to budge. I have been soaking it in kroil and even sticking a punch in the bolt hole that holds the shock on and beating it downwards with a . it still hasnt budged. Any ideas?
    I may just have to look for a set of forks to buy if i cant these apart, as i cant rebuild them then. Larry
    OK
    5,450
    I sent you a pm. I have an 83 200es if you want it. Just come pick it up. I'll throw in 3 tri-zingers not running.. lol
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Oct 2011
    kansas
    21
    dcreel, thank you very much sir. I replied to your pm.
