Thread: Honda 200x atc problem
    Oct 2011
    Missouri
    9
    Its running decent.I still have to turn the idle screw in alot to make it idle but its definitely idling too high.What causes it to back fire?
    6,808
    Your idle jet is part clogged .
    Jan 2011
    Brazil, Indiana
    2,087
    A lean condition will cause backfiring on deceleration. Like Shortline10 said, clean your idle jet. Use compressed air do not poke wire in there or use a drill bit. you will woller it out and cause it to be rich.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Oct 2011
    Missouri
    9
    Ok I'll try that and see what happens.Also on cleaning the fuel filter when I unscrewed the nut on the bottom of the tank all that came out was a rubber tube attached but don't I need to clean the screen thats in the tank too?And whats the best way to get it out?Thanks for all your advice.
    Oct 2011
    Missouri
    9
    And cleaning the jet out worked!Thanks alot.
