Thread: how to stop the piston from turning...
    Oct 2011
    Michigan's UP
    3
    I am trying to remove the stator on my 83 200e and am stumped as to how to stop the bolt from spinning as a try to loosen it... any help? I'm sure I'm missing something easy
    "This is Big Red Six, standing by..."
    1983 ATC200E - Big Red
    1994 Honda Civic DX - Bigger Red
    1983 Dodge Ramcharger - Biggest Red
    The best way to remove a bolt on part of the rotating assembly would be to use an impact gun. If you don't have access to an impact gun, you can put the piston at the bottom of its travel and feed a rope into the cylinder through the spark plug hole.
    Oct 2011
    Michigan's UP
    3
    Thumbs up
    oh jeeze, I forgot all about stuffing a rope in the spark plug hole. Thanks for the reply!
    Tucson
    1,652
    Assuming the motor is still in the trike just put it in gear!!! That is if the chain is still on.
    Pacific NW
    4,255
    Quote Originally Posted by bstrahl View Post
    I wonder if it matters if the valves are closed? with that rope in there.
    like on it's way to TDC on compression stroke/
    I'd also like to know which of these life critical bolts and nuts really are
    left or right handed threads.
    The manual is not very clear.
    Does that stator project require a flywheel puller?
