Thread: 85 tri-z 250 carb
    tbo is offline New to the board Arm chair racerNew to the board
    Apr 2010
    grande prairie
    13
    85 tri-z 250 carb
    i have an 85' tri-z 250 with a stock carb. i also have the stock carb of of my 85 250r. would it be worth it for me to put my r carb on my z? the z is mostly stock, dg silencer is about all.
    House Springs MO
    5,496
    Upgrade it to a newer PWK carb and never look back. I personally wouldn't mess with the old round slide 250r carb. But thats just me.
    Apr 2010
    grande prairie
    13
    i put the 86 carb on my r. i do have a 39 off of a 2002 cr 250 that i was going to put on my r if its not too big, then i could put the 86 carb on the z. what kind of mods would i need on my r for the 39 mm carb?
    na
    5,702
    The 85 carb on the Z works perect IMO and is not really worth changing unless it is bad for some reason.
    If you are going to put a 39 mill carb on a 250R, you are going to need a host of mods done to it, to make that work correctly.
    You will need or want: porting, tighter compression, better reed system, and a good pipe at least. Otherwise if you leave it all stock and run that 39 mil carb, you are going to have a machine that bogs down low, but revs to the moon.
    Proudly NOT a member of
    "Team on the Teat"
    Apr 2010
    grande prairie
    13
    Well i have the pipe and i was planning on getting some porting and vforce reeds this winter. Can i get away without the tighter compression? Arent the r's maxed out there as far as running pump gas goes?
    House Springs MO
    5,496
    Quote Originally Posted by tbo View Post
    This is the combo I ran with my '86 250r and it ran great in all ranges of the powerband.
    I ran a thin 89 cr250 head gasket to bump up compression, still on 93 octane at 32:1
    Lightly ported
    .040 Weisco
    Boysen Rad valve
    Paul Turner Hi-Rev Pipe
    Duncan Racing 39mm PWK
    I never had a problem with it, but I wouldn't of ran that carb on the stock engine or just a piped engine.
    Getting back to your original question, what is wrong with the carb on your Z? I was assuming there was an issue that's why I recommended a PWK. Something around a 36mm for a stock engine. But if nothing is wrong with it leave it alone unless your dead set on changing it.
    Apr 2010
    grande prairie
    13
    The z carb is in working order I just figured the bigger r carb would be a bit of an upgrade. The z carb is already out for jetting purposes.
