Results 1 to 7 of 7
Thread: Common ATC 70 problems?
    Aug 2009
    going to look at an 85 70 tomorrow evening, what are some common problems with them?
    have had a few 110s, but never a 70. will check hubs, bearings and of course the motor.
    just wondering if there's any know areas problem areas to keep an eye on.
    Dec 2010
    S.E. Illinois
    1,178
    IMO, the big thing to check is the frame behind the headtube. they tend to tweak here instead of the forks first. look in the tank for rust and along the bottom edges also. the rest i think you have mentioned. if i missed anything i'm sure someone will chime in. good luck on your buy.
    74 HONDA ATC 70
    Parts Man is offline Check my feedback on 3WW before you buy any thing from me. Arm chair racerNew to the board
    Jul 2006
    Florida
    28
    Tank rust for sure.
    Aug 2009
    Thanks guys, had to work late last night but will see it this evening... guys says its a nice 85 that runs good. only $200
    Cold Lake, Alberta, Canada
    3,019
    Pull starter, pull starter, pull starter! If it doesn't have one, that little beauty could cost you around $100 alone. Although $200 seems decent if it's complete. I've also heard that the seat pans rust out; but I've seen repro's available on hondaatc70.com. Definitely post some pics if you get it.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Michigan UP
    1,005
    My only problem is that I wanted one for years and now have seven of them, all since last summer.
    B S is offline New to the board Arm chair racerNew to the board
    Jul 2011
    CHICO,CA
    40
    $200 seams like a good price are they hard to find in area?
