Results 1 to 8 of 8
Thread: sprocket questions
    Oct 2011
    Subligna, Georgia
    51
    Question sprocket questions
    im currently working on my 1984 honda 200m ive got it snorkeled and im goin to put sum 28" outlaws on the back my question is when u want to lower the gear ratio you add teeth to the rear sprocket correct? i saw a guy on here that had honda 200m and he had a stock front sprocket and then a 50 tooth rear (47 is stock) and he said that he had enuf power to turn larger than 28s...my second question is where in the heck do i find aftermarket sprockets with more teeth im havin no luck and i know they are out there cause that guy had one...thanks in advance my friends
    1984 Honda ATC200M
    2009 Honda Rancher 420AT
    May 2011
    eden,ny
    3,481
    Oct 2011
    Subligna, Georgia
    51
    sweet thanks alot man...anybody have any suggestions on what tooth sprocket to get im thinkin 50
    1984 Honda ATC200M
    Oct 2011
    Subligna, Georgia
    51
    anybody????
    1984 Honda ATC200M
    Abrams, Wisconsin
    739
    here's a little formula i found in a 4x4 mag. first, you will need to calculate your final drive ratio. to do this, divide the number of teeth on the rear sprocket by the number of teeth on the front sprocket. (example: 13t front, 44t rear. 44 / 13 = 3.385. so that is a 3.385 to 1 ratio)
    next, multiply your new tire diameter by your current ratio. then divide by your old tire diameter, the answer will be your new final drive ratio to work with your new tire size.
    then find the front\ rear sprocket combo that comes closest.
    86 250sx - old reliable
    another 82 110
    -gone but not forgotten-
    82? 110 - why did i sell it??
    84 225dx - meh, it was a pile
    Oct 2011
    Subligna, Georgia
    51
    ok make sure i did this right i got 11 tooth front sprocket with 47 tooth rear im wantin to run 28s and i currently am runnin 25s so....
    47/11=4.272 4.272x28=119.636 119.636/25=4.785 so it would end up bein a 52 or 53 tooth sprocket in the rear
    1984 Honda ATC200M
    Abrams, Wisconsin
    739
    that sounds right.now, if you're just going for mud running you could also gear a little lower yet with an even bigger rear sprocket for more grunt, but you will lose top end speed. sprockets are fairly inexpensive, you might want to get a couple sizes to experiment.
    another 82 110
    Oct 2011
    Subligna, Georgia
    51
    yea i agree thanks alot for help man
    1984 Honda ATC200M
