here's a little formula i found in a 4x4 mag. first, you will need to calculate your final drive ratio. to do this, divide the number of teeth on the rear sprocket by the number of teeth on the front sprocket. (example: 13t front, 44t rear. 44 / 13 = 3.385. so that is a 3.385 to 1 ratio)
next, multiply your new tire diameter by your current ratio. then divide by your old tire diameter, the answer will be your new final drive ratio to work with your new tire size.
then find the front\ rear sprocket combo that comes closest.
86 250sx - old reliable
another 82 110
-gone but not forgotten-
82? 110 - why did i sell it??
84 225dx - meh, it was a pile
