Results 1 to 3 of 3
Thread: gas proof paint???
    B S is offline New to the board Arm chair racerNew to the board
    Jul 2011
    CHICO,CA
    40
    gas proof paint???
    does any one know of any paint that is gas proof or a clear coting that i could use over it i keep having to paint my 84 200X tank white but it loks like cr*p
    any help would be great
    audioworks04's Avatar
    Oct 2008
    Kansas City, KS
    332
    No such thing as gas PROOF paint, but any paint with hardener in it is gas resistant. Any auto body or tractor implement with a hardener with it should work out fine for you, but you will want to let it cure out. Sounds like you are using a which will not work in an environment with solvents, you will need to spray it with a quality paint or clear with hardener.
    86 atc250r stock sand only
    88 NX250 mint rainy day
    Nov 2011
    Oregon
    28
    you are correct, you need to use an automotive style paint best being a 2 stage basecoat-clearcoat and a couple extra layers of clear would help your cause, while you will use an activator in your paint I would also use a quick flash thinner, and if your tank is plastic not use as much clear but you will need to add a flex agent and possibly a fish eye eliminator in it since the plastic will be contaminated from the gas...
