Page 17 of 19 FirstFirst ... 7 15 16 17 18 19 LastLast
Results 241 to 255 of 279
Thread: National 3 wheeler TT race Ashtabula
  1. #241
    Poco Loco's Avatar
    May 2013
    Clap Saddle California
    389
    Shart Guard .......Use it !
    Pink Powerwheels Barbie trike
    1985 Crash and Burn champ
  2. #242
    Sep 2011
    New Castle, PA
    1,134
    So if there are not enough to do a 200 class then what would I run with? I'm too slow to keep up with r's and daddy X's so what then? I want to go and race my Powroll replica bike. Stroker powerrrrrrr
    Gone:
  3. #243
    Sep 2011
    New Castle, PA
    1,134
    So when you say vintage 250r class that means I would run with s? What if someone is running a 300r or a mugen?
    Gone:
  4. #244
    Fresno Ca
    2,695
    It's mainly rider and setup not hp, don't worry
  5. #245
    Sep 2011
    New Castle, PA
    1,134
    I saw the track, its kinda of a dusty (maybe because it was so dry) tight turn one, and maybe 4th-5th on the main straight?
    The +2 swinger should help whip it around some turns and I'll probably drop a tooth or two on the front so I can gain more torque without pinning it on the main straight. I saw two minor jumps, so I would probably set susp. to 3 with a medium-low preload. Maybe put the forks about 1-2" higher in the trees.
    There is nobody else running a #4, is there??
    Gone:
  6. #246
    Mar 2012
    Hamilton,Ohio
    116
    Quote Originally Posted by rg97 View Post
    I could be wrong but I thought a shorter swingarm was better for flattrack/tt?
  7. #247
    May 2013
    Brownsville, Tn.
    1,271
    Just show up and have fun. It's a neat TT track.
    Here are some pic's of my 200X TT Bike at Ashtabula back in the 80's. I really needed a Hoosier front tire on that bike.....
    * Nicholson 500 Race Bike *
  8. #248
    Soutwestern PA
    2,040
    Classes are determined based on who / what signs up.
    2012 - Was Unlimited Open (anything on 3) and Vintage (period correct machines). It was divided by machine.
    2013 - Was "A" class and "B" class. It was divided mainly by rider skill level.
    Stock and modified minis (70s, Zingers...) always have a class too.
    So, if you showed last year on a 250R (for example), you could run with the big dogs OR in the less competitive B class depending on your skill level.
    I ran B class with other R's, TriZs, Tecates, 350Xs, 200Xs, ATC200, etc....
    Bottom line: Show up with your 3 wheeler and they will fit you into class appropriate for your machine and ability.
  9. #249
    Soutwestern PA
    2,040
    A bone stock 1985 250R taps out in 6th gear well before the end of that straightaway.
  10. #250
    May 2011
    eden,ny
    3,481
    I was running +1 tooth on the front and -2 on the rear of my tecate and was shifting into 5th right in front of the announcers booth.
  11. #251
    Sep 2011
    New Castle, PA
    1,134
    Is there a practice type of time?
    Gone:
  12. #252
    Soutwestern PA
    2,040
    Yes, 3 sessions. Friday, then Sat before the heats, then Sunday before the mains.
  13. #253
    Sep 2011
    New Castle, PA
    1,134
    Proper riding attire needed? Other than a helmet of course. ..
    What I'm trying to ask is if I show up in jeans and a long sleeve shirt will they say "no you can't race"
    Gone:
  14. #254
    1,641
    I would strongly advise buying some real riding boots.There was a guy last who got mauled up.Think he was off work for a few months.It is a really good time.Everybody had a good time.Only down fall is you will want more of it!Kiester explained it very well.Rider ability really determines the out come for sure.
  15. #255
    Nov 2007
    ulysses pa
    1,231
    you'll need boots at least 8 inches tall too. or maybe just boots over the ankle, either way you need boots. basically you can sum it up by, helmet, gloves,eye protection, long sleeves, and boots. you can run in jeans but you have alot of time before this race and i guarantee if you cant afford new riding pants by then someone that races has a pair to cut you a deal on.
