Thread: Polaris 250r parts???
    Mar 2012
    MI
    Anyone know where I can get some parts for a 1985 Polaris 3 wheeler? Bikebandit does not have a thing!! Looking for: swing arm bolt(right side) and bushing for swing arm. Any help would great!!
    Apr 2002
    s.w. michigan
    6,498
    It has been awhile since I made my own swing arm bushings for my Polaris trike but , like you, none was to be found.
    If I recall correctly I used 1 inch round derlin, cut to length and drilled the proper sized hole.
    Now I do not do a bunch of riding but after some five years (or maybe a few more), swing arm is still tight.
    After thinking about what I used, I may have used alu round stock, i inch.
    Howdy ! I beleive I also made you a set, input ???
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by 450guy View Post
    While I don't have a bolt ( I will double check to be sure ), I do have some German enginered Bushings. I sell these as a Kit: 2 bushing, 2 center pins and 4 seals. These are 10x better than OEM ( IMO ). While they do cost a little ( $90 shipped in the US per kit ), these should last a long time ( brass and harded steel center pins, good seals ). You can PM me if your interested.
    Thanks
    Howdy
    Soutwestern PA
    2,040
    Quote Originally Posted by Howdy View Post
    Thanks
    Howdy
    I bought a set of these and $90 is an absolute steal (especially considering these parts "don't exist" other than at 3WW). I don't have the machining knowledge to wager a guess as to the tolerancing, but their fit is so perfect it will make you want to puke! Well done, gentlemen. A+++++
    Big Mike's Avatar
    Hanson, MA
    1,062
    Howdy,
    Any chance you can bring a set of these to Trikefest, and I will buy them from you there?
    Currently Own:
    1985 ATC 250sx
    1986 ATC 350x
    Projects/Parts machines:
    1980 ATC 185S
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Big Mike View Post
    Howdy,
    Remind me a week or 2 before then and I will try to bring some with me.
    Howdy
