when doing this swap is there a big difference between the lengths? can i use a 400ex cable (with a 400ex throttle) without any problems other than maybe rerouthing the cable?
I have done this. You will be okay. the 350x cable is less than an inch longer than the 400ex cable internally and the cables are interchangeable between bikes. The 400ex and 350x have nearly identical throttles and cables. I used the 350x throttle with 400ex cable and carb.
85 350x
84 tecate 3
84 ATC70 http://www.3wheelerworld.com/showthr...C70-Buildup!!!
My youtube! http://www.youtube.com/user/vortex812
Can a 350x cable be used with the 400ex carb?? Or should I get a 400ex cable?
I just picked up a good used 400ex carb on the cheap and am wondering what I need to swap this into the wife's 350x and have it work properly and dependably.....
Thread resurrected due to using the search engine! LOL!
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
You can use both. Only difference is the 350X cable is a bit longer.
