Results 1 to 15 of 15
Thread: Shock find on ATC 70!
    Cape Town, South Africa
    111
    I had the pull start off check the points gap on my newly aquired ATC 70 only to find some idiot has ruined the crankshaft.
    The threaded part of the shaft has split in half and the nut and washer are missing.
    There doesnt seem to be much thread left that is still okay.
    Here is a pic(sorry about cell phone pic quality)
    Is there any way the crankshaft can be saved?
    1984 Honda ATC200ES BIG RED x6
    1983 Honda ATC200E BIG RED x3
    1984 Honda ATC70 LITTLE RED
    1983 Honda ATC185S(200E engine)
    1984 Honda ATC200X
    1985 ATC 70
    1983 ATC 70
    Mar 2007
    Texas
    5,045
    no. you have to get a new crankshaft and split the motor and replace. if the motor is in mint working order, then it's worth the time. if not then get anotehr engine. less costs and time for sure.
    ________________
    https://www.mikesatvfix.com
    Feb 2009
    Rome,NY
    1,046
    160 lifan time
    Big Mike's Avatar
    Hanson, MA
    1,062
    My 185S looks like too!! But I cant complain for $40 that I paid for the machine.
    Currently Own:
    1985 ATC 250sx
    1986 ATC 350x
    Projects/Parts machines:
    1980 ATC 185S
    Lancaster, PA
    1,738
    I would try to to save it, first get the flywheel off, use a steering wheel puller (two bolt version) and thread in to where the recoil cage bolts on. from there see if you can file the damaged raised areas off and I would then use a thread file to fix the threads and then see if there is enough thread to use when all done. They are a metric thread but I do not remember which one. Worth a try?
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    111
    Could an engineering shop not weld a new shaft onto the end and cut a new thread?
    1984 Honda ATC200X
    1985 ATC 70
    1983 ATC 70
    malibulvr's Avatar
    malibulvr is offline At The Back Of The Pack Arm chair racerFirst time rider
    Lockport, NY
    203
    Quote Originally Posted by GTO View Post
    Probably but then it would have to be disassembled and balanced.
    111
    I see there quite a few 2nd hand cranks on eBay for $80 to $100 incl shipping which might be my best option and probably cheaper than engineering shop.
    I see I must use a 81 to 85 crank as older ones have a different part no.
    1984 Honda ATC200X
    1985 ATC 70
    1983 ATC 70
    Howdy's Avatar
    Celina, Ohio
    10,079
    Yes, I have actually fixed one that was brought to me after it was stripped. Took about an hour or two to weld, machine and rethread it. Last I heard about 5 years ago it was still running. So yes it can be saved, but you have to be very very careful doing the fix. .
    Dec 2007
    Quebec,Canada
    1,014
    Easy,remove the flywheel,cut the old thread,drill the crankshaft for a M8-1.25 bolt and tap thread in it.......I repaired many of these like this,no need to remove the motor or split the cases
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    111
    Quote Originally Posted by atc500x View Post
    Thanks will give it a try when I get around to it.
    Also I am worried that it is not going to be easy getting the flywheel off with the shaft so flared as it is.
    1984 Honda ATC200X
    1985 ATC 70
    1983 ATC 70
    111
    I got her running tonight, lots of smoke and cam chain noise. So I will try the to drill and tap the shaft, if it works then its time for a top end overhaul.
    1984 Honda ATC200X
    1985 ATC 70
    1983 ATC 70
    111
    I tried to remove the flywheel last night but failed.
    I had to chisel off the flared part, I ended up flattening the point of the puller but it is not a high tensile bolt so I will go and get a new bolt to fit today.
    I am going to try heating it up, is this pretty safe to do so?
    I will keep the flame on the crank area.
    1984 Honda ATC200X
    1985 ATC 70
    1983 ATC 70
    OHIO
    2,857
    Try using a rubber mallet or a soft deadblow hammmer when putting pulling force on it.
    111
    I got it off in 5 minutes with some heat, cut off the end and tapped a thread and fitted a bolt.
    The cam chain tensioner isn't working hence the cam chain noise when i had it running, I found the spring from the tensioner lying loose in the bottom.
    1984 Honda ATC200X
    1985 ATC 70
    1983 ATC 70
